05-10-2007, 08:07 PM
2007 25' Safari FB SE
Kennesaw
, Georgia
New Safari 25; a few quirks...
Hey, got a new 25 FB Safari SE LS; a coupla issues/questions:
1) Took a shower and about an hour later saw trickle of water coming from left front corner of shower area (not actually in the shower) on floor of camper, right by the access panel to water pump. Water pump floor area was dry, though. Any ideas?
2) Dinette table is rickety; that is, it has a lot of play in the upper brackets that hold it in place, so when you put an elbow on the table it moves down on your side and up on the other. Adjusted the single leg with no luck.
3) Has anyone converted the dinette area into a "proper" couch, either with cushions/parts from Airstream or otherwise? It would be nice to convert it into a couch in the evenings.
Otherwise, enjoying the new camper; we had a pop-up before and this is some good living.
Thanx, Lance
05-10-2007, 08:41 PM
Aluminut
2004 25' Safari
Check the QC threads. The leaky shower has been an issue for years. If yours is the same thing, it doesn't have enough or any caulk....if it's the same thing that I read on the QC threads.
As for the table, I haven't seen a totally firm one, but if yours has lots of play......
05-10-2007, 08:55 PM
Kennesaw
, Georgia
Sorry, where are the QC threads?
Lance
05-10-2007, 09:54 PM
NE
, Indiana
Tennis Man,
Congratulations on your new AS. Lots of information here to help you remedy those little *quirks*. Not sure how to link a thread. Try a search on "2007 Model Year Quality".
Randi
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
05-11-2007, 12:02 AM
2007 27' Safari FB SE
Tracy
The shower seems indemic with this model as well as others. I just got some bathroom sealant and went to down on all seams.
The dining table into lounge is pretty easy. We also got a large lounging pillow about 6 feet long from Costco that we keep on the bed when not using it. This covers that back of the lounge against the back wall when set up and makes it more cozy. The more pillows the better.
We too had a popup and then a hybrid. Welcome to the land of quality!
05-11-2007, 05:55 AM
2012 28' International
New Orleans
, Louisiana
Lance
Get some big eyes and look over the bottom of the shower door real good you will find some small gaps which let the water leak, seal. Reglue the floor covering then use some caulk to seal the edges.
Use the search function for QC and other questions it will point you in the right direction.
The wife and I love our 25 just the right size for our needs.
Good Luck Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
05-11-2007, 07:20 AM
Aluminut
2004 25' Safari
Here is a link to the 2008 model year QC thread. This thread also has links to 2004, 2005, 2006 and 2007.
http://www.airforums.com/forums/f142...ity-31210.html
The shower issue is well documented throughout most of the threads.
It's a lot of reading, so give yourself some time.
05-11-2007, 10:00 AM
2000 31' Land Yacht
On the dinette table, I suspect that you don't have the brackets on the wall properly engaged. It is very easy to only get one hooked, which will make the table unstable. When both are properly engaged, the table is very stable.
05-11-2007, 11:32 AM
Kennesaw
, Georgia
Do you mean upper or lower brackets? There is a lot of play in the upper brackets where the tab of the table slides into the slot of the bracket.
The lower (under table) brackets that the wire-rod-like support sits in is not very snug; the rod can easily move up and down in the support.
Lance
05-11-2007, 12:49 PM
2000 31' Land Yacht
Lance
The upper brackets should be quite tight. Perhaps the lower brackets are not properly located and are not forcing the table all the way up. I suggest looking at another unit with a dinette, to see what is different. Your problem is NOT normal.
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
Welcome to the forums TinnisMan. I used to play on and ALTA team in the Marietta area. You should plan on joining us for the Fall Forum Rally in Hiawassee at Lake Chatuge. The thread with the information is at: http://www.airforums.com/forums/f288...ins-32035.html in case you hadn't come across it yet. There are lots of good folks, good food, and good music. You'll see everything from 1950's models to brand new ones and lots of variations in between. But you'd better make a reservation soon, the sites are going fast.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
05-11-2007, 03:49 PM
2004 30' Classic Slideout
Fenton
, Missouri
The leaks in the shower come from the door area. Usually the left and right corner where the vertical edge of the door frame meets the horizontal piece. The other place is the inside lip of the bottom door frame. The lip extends over the shower enclosure and my dealer noted that splashing water on the floor gets up under that lip where there is insufficient caulking to seal the lip against the inside of the shower enclosure.
I can tell you that this is a bear to fix. I remember my 2001 Safari was never fixed completely. I'd always find a drop or two of water running down the wood just below the frame in the left corner. I had my dealer work on it 3 times and once at Jackson Center. It might stop for a while but it always seemed to come back.
My 2004 Classic took 2 trips back to the dealer before they got it sealed. Same bottom left corner same problem.
Jack
Jack Canavera
STL Mo.
AIR #56
05-11-2007, 04:13 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
table
My table and every table I've seen in the 25 FB has about a 1/2 inch deflection due to the single leg system at the front of the table and the bracket design at the rear. Not a biggee for us though.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
05-11-2007, 08:55 PM
2005 22' Interstate
Afton
, Virginia
The dinette on our Interstate rattled around because of the fittings. I took a wine cork, cut some little slices out of it, and used airplane cement to glue them to the wall such that they made the table snug when it was set as a table. When we use it as a bed, no problem...
Hope this kludge helps.
