RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-01-2007, 07:29 PM   #1
2007 25' Safari FB SE
Kennesaw , Georgia
Question Fridge on a slant?
Hey, I know this is a newbie question, but here goes...
We were told by the dealer tech -not- to run the fridge on a slant; we have a driveway that is slanted front to back about 15 degrees and would like to run the fridge overnight prior to leaving on a trip. Some fellow campers tell me that it's o.k. to run it on a slant for a short time.
What do you think?
Thanx, Lance
TennisMan is offline   Reply With Quote
Old 06-01-2007, 07:37 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Fridge level is important
Originally Posted by TennisMan
Hey, I know this is a newbie question, ... What do you think?
Lance,
I think its a good question worth revisiting. Check this thread for more insight.
Tom
Old 06-01-2007, 07:42 PM   #3
1960 22' Safari
in the wilderness , The great Mojave Desert
Allright, It's O.K. IF you are willing to replace it with a new one.
Running it on a slant (short version) causes the boiler section to overheat. This causes a blockage in the cooling unit which cannot be repaired. Thus a new Unit.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 06-01-2007, 07:44 PM   #4
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
hi- I've always heard that it is NOT good to use the ammonia-evap type fridges on anything but a fairly level setting. If yours is that kind, maybe you could use the tongue jack to get it as level as possible?
tphan is offline   Reply With Quote
Old 06-01-2007, 07:50 PM   #5
Kennesaw , Georgia
Thanks; looks like I'll not be running it overnight in the driveway.
Lance
Old 06-01-2007, 08:14 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Can't you jack up the tounge untill it is level?
Richard
Old 06-01-2007, 08:28 PM   #7
Naples , Florida
Older fridges had to be 'dead-on level' in order for them to operate correctly. What most folks don't know is that there are a number of smaller tubes with-in the outer tubes that you see from the back of the units, and the ammonia/hydrogen mix depends on gravity to operate properly. The orientation of these inner tubes must be precise (as determined by a level fridge) to work as designed.
Newer units can operate in an RV that is 'comfortable to walk in' as stated by the manufacturers. Unfortunately, 15* does not qualify for this either .
Do your fridge a favor and don't light it up unless it's 'level'.
lewster
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 08:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 08:40 AM
RV Ideas to consider ??? FrankR General Repair Forum 18 09-18-2002 11:43 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 07:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 07:44 AM
