RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-08-2014, 03:48 PM   #1
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Fantastic Fan Reverse Flow Switch
I own a 2007 Airstream 25' FB SE with a Fantastic Fan over the dining area. The fan only works in one direction and moves air out of the trailer. I understand that Fantastic Fan use to have conversion kits available that would allow the fan to operate in both directions. Fantastic Fan does not have the kits or parts available.
Does anyone that has installed on of their kits have any information on the type of switch they were using and their instructions on rewiring the fan?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-08-2014, 03:57 PM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Give this a shot.
I ordered reverse switches about a year and a half ago, but in internet speak, that's ages ago.
Fantastic Vent RV Vent FanÂ* Adohen Supply
2013 25 FC FB (Twin)
2013 Suburban 2500
https://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-08-2014, 03:58 PM   #3
dznf0g's Avatar
Oswego , Illinois
Call FF and ask for the kit. IIRC it was about $50 and has a switch and a bit of wiring and good instructions.
-Rich-
Old 10-08-2014, 04:42 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If the kit is no longer available, it is pretty simple. If your fan doesn't have a cutout for the switch you will have to drill a hole in the fan fascia to mount it. If your fan does have a rectangular cutout for the switch you can try to find a switch to match. You want a 2-pole On-Off-On switch available at Radio Shack or most marine and auto parts dealers. It should be rated for 7-10 amps as I think the fan draws 4 or more.
On the plate surface where the controls are mounted there are four screws. Remove them and the screw inside the center of the lid opening knob and remove the knob. The plate should then be loose and hang by the wiring. There will be two wires, probably a black and a white which will come in through the side of the fan frame. Decide on where to mount your switch. If possible rearrange the wiring (it is held in place with hot glue) to reach the spot. If not you will have to splice in more wire. Cut the wires (make sure the wall switch that controls the fan is off) and wire them per the sketch below.
Al
Name:	Reverse switch wiring.jpg
Old 10-08-2014, 04:47 PM   #5
1974 Argosy 20
Kooskia , Idaho
I got mine from FF about a year ago for $45 (too much, but the right switch and instructions came with it). I can't imagine why it would have been discontinued.
Old 10-08-2014, 04:54 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Or you might find a working FF "bi" in a wrecked SOB. Check your local junkyard. It doesn't have to be an Airstream.
Fantastic fan does not work in reverse djpierce Roof Vents, Skylights & Fans 18 09-24-2013 03:27 AM
Fantastic Vent reverse switch bolerama Roof Vents, Skylights & Fans 77 03-24-2012 09:11 AM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 08:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 02:30 PM
reverse switch on Fantastic Vent bradk Roof Vents, Skylights & Fans 19 07-13-2006 12:11 AM
