Old 02-28-2023, 08:54 PM   #1
1965 26' Overlander
1960 28' Ambassador
1975 20' Argosy 20
Upper Black Eddy , PA
Zolatone Flex paint…no longer available?
After stripping the permanently stained dreaded mouse fur from the interior walls of the front bedroom in our 2005 Bunkhouse, we’re left with not-so-nice interior aluminum walls…etched from the adhesive used. The plan was to use the roll-on Zolatone Flex Pearl paint. So the search to find a distributor to obtain some samples ensued. After Google failed to yield any working phone numbers for Zolatone, I finally spoke with a former distributor who delivered the news…apparently Zolatone interior paints closed down operations in the Fall of 2022…
Has anyone else heard similarly? I see the Zolatone Splatter is still available from some sellers…but I’ve had no luck finding the Zolatone Flex Pearl paint any where.
Is there a good alternative…with good or better adhesion, wear ability, and ease of application?
kdenault is offline   Reply With Quote
Old 03-01-2023, 08:43 AM   #2
Paradise , Texas
Auto body tool mart sells zolatone. It's only available in a handful of colors
Crackerman is offline   Reply With Quote
Old 03-01-2023, 09:01 AM   #3
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Many here have simply used a high quality interior paint-over-primer, but it's not as durable as zolatone, but then again, much easier to scrape off if you want to redo it.
One advantage of the mouse fur is that it does offer a bit of insulation, a much appreciated feature if you have a floor plan with a bed adjacent to the shell and you touch the wall while sleeping on a cold night.
Zolatone doesn't offer as much insulation as mouse fur, but it's plastic texture has a tad more buffer than bare aluminum or paint.
Perhaps you could coat with whatever color of Zolatone you can get your hands on, then paint over that.
skyguyscott is offline   Reply With Quote
Old 03-01-2023, 04:15 PM   #4
1965 26' Overlander
1960 28' Ambassador
1975 20' Argosy 20
For our purposes, I’m OK with going the paint route. What type of primer would be best? For the top coat, is latex recommended or another type of paint? I’m less oriented to painting a less-preferred color of Zolatone and then painting over it with a non-Zolatone paint…(one of my other Airstreams had latex painted over Zolatone and it was a nightmare to strip). I’ve tried I’m ok with a paint type that is less durable, but looks good and has decent adhesion and wear-ability.
Old 03-01-2023, 06:22 PM   #5
1966 22' Safari
Fredericksburg , Texas
We stripped the mouse fur on our 66 Safari the best we could. We washed the interior aluminum down with Simple Green. Then we rolled Kilz Adhesive on the aluminum. Finally, we painted with Zolatone Flex. The Kilz is tough stuff and stuck well. Good luck
Bubba L is offline   Reply With Quote
Old 03-02-2023, 04:40 AM   #6
1965 26' Overlander
1960 28' Ambassador
1975 20' Argosy 20
Yes…but, unfortunately, Zolatone Flex is no longer available. I could use Kilz as a primer, but then follow with what type of paint?
Old 03-02-2023, 06:35 AM   #7
1994 30' Excella
Mississauga , Ontario
Out of curiosity I did a Google search and lots of sources for Zolatone came up. Surprised you can’t get it.
Al and Jean
TAC ON-3
Old 03-02-2023, 06:35 AM   #8
1966 22' Safari
Kilz ADHESIVE is such a tough primer just about all paints are compatible. I would choose a paint that is durable and can be wiped down with a cleaner. Go to a commercial paint store and discuss the possibilities. Good luck
Old 03-02-2023, 04:47 PM   #9
1969 18' Caravel
Images: 20
Practically any good to high quality latex paint would do. Ideally you want a paint that has high mold and moisture resistance and you can scrub.
Old 03-02-2023, 04:54 PM   #10
1965 26' Overlander
1960 28' Ambassador
1975 20' Argosy 20
Zolatone Splatter paint is readily available. From my understanding, this is a spray application. The roll-on application product, Zolatone Flex, which is part of Zolatone’s architectural product line, is no longer being produced due to significant supply chain issues. Have you been able to find any Zolatone flex products available?
Allstays Camp & RV app no longer available for Android devices RxGuy On The Road... 5 11-30-2018 05:32 PM
To Zolatone or Not to Zolatone jonplayers Upholstery, Blinds, Walls & Interior Finishes 7 07-18-2017 03:50 PM
Original Zolatone or New Zolatone - Value judgement? robwok General Interior Topics 1 12-05-2014 09:34 AM
'99 25' Airstream - no longer available richard ll Forum Admin, News and Member Account Info 4 02-28-2008 09:51 AM
parts no longer available! jking Exterior Restoration Forum 2 05-11-2004 06:10 PM
