Old 02-07-2019, 08:14 AM   #1
1973 29' Ambassador
Wetumpka , AL
Twin mattress
I have a 1973 ambassador 29' rear bath, twin bed. I need new mattresses. Where is the best place? What are the best mattresses?
Evdreaming is offline   Reply With Quote
Old 02-07-2019, 08:50 AM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
There is a blue bar just below where you click to login which contains the word SEARCH. Click there, enter "mattress" and you will find numerous threads addressing your query. I believe you will soon discover that defining "the best" is fleeting.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 02-07-2019, 10:58 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Thumbs up Twin mattress
Greetings Evdreaming!
Welcome to the Forums!
Another option is decide for yourself which mattress suits your needs best. Check your local yellow pages for mattress manufacturers and travel to their showroom with a measured drawing of your mattresses (they will likely be slightly smaller than a standard twin) -- then for a slight upcharge, the manufacturer will likely produce the mattresses of your choosing to your custom dimensions -- this is exactly what I did with my Overlander. I was so pleased with my Overlander mattresses that I purchased new beds for my home from the same line a year later (Lebeda).
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Futon Mattress to Replace Front? Gaucho Bed Mattress? lanajane General Interior Topics 8 05-26-2016 04:07 PM
what is the best mattress for our 2003 safari 25 with a full size mattress DandC 2000 - 2004 Safari 10 04-11-2016 06:12 PM
Mattress corner detail for 32 x 74 twin mattress Silverexpress 1997 - 1999 Safari 2 09-29-2013 06:00 AM
Twin Mattress dmadam Cabinets, Counter Tops & Furnishings 3 09-15-2006 07:14 AM
