Old 04-15-2021, 10:26 AM   #1
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
Rear fiberglass endcap won't fit back in. What am I missing? 68 ambassador
For the rear fiberglass end cap in a 68 Ambassador, how does it attach to the frame around the back window? Did it get riveted directly to the top and side flanges of the window frame? Or is there supposed to be a trim piece that ties the end cap to that flange? I can't seem to get the rivet holes by the window to line up. It's really wonky. Thanks! Post pictures if you can.
zen_stream is offline   Reply With Quote
Old 04-15-2021, 10:59 AM   #2
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
I don't have any practical advice but I want to follow along. In the videos I have seen it is always a ridiculous dance before they seem to go up.
NWA MTB
Peter417 is offline   Reply With Quote
Old 04-15-2021, 10:59 AM   #3
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Promise you won't laugh?
I was helping a friend and his son reinstall a rear end cap in his '72 a few years back. We fought with that thing for an hour. Some of the rivet holes lined up perfectly, some no where close. Turns out we had it upside down. So much for marking things as you take them apart, eh?
Try flipping it over.
www.nesa.org
Air No. 6427
Old 04-15-2021, 12:45 PM   #4
Long Island , New York
Did you remove the end cap, after first labeling everything carefully? Maybe the structure sagged if you did not shore it up correctly? [especially if you did exterior work on that end, without the end cap in place] Check the exterior seams for signs that the structure has shifted/dropped since the end cap was removed.
Have you checked the Ambassador forums? [Edit -- see your thread therein -- linked below]
https://www.airforums.com/forums/f23/
1966-1969: https://www.airforums.com/forums/f174/
Also maybe check these "Ambassador end cap fit" search results:
https://www.google.com/search?q=Amba...=airforums.com
Also FWIW: https://www.airforums.com/forums/f14...odel-3029.html
1974 Ambassador full restoration -- 127 posts:
https://www.airforums.com/forums/f7/...on-217749.html
Is this earlier thread of yours the same Ambassador?
https://www.airforums.com/forums/f17...on-206001.html
Good luck.
Let the music lift you up . . .
OTRA15 is online now   Reply With Quote
Old 04-15-2021, 02:20 PM   #5
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Well, maybe the reinstall in our '68 Overlander went better than expected but here it is... My son and I, precut 2x3 to hold up the center at the first rib... lift into position, just lays on the top of the rear window frame, hold up center with board, using small picks begin looking for holes to line up either on top or sides of window and also a the edge at the first rib, begin installing clecos. On ours we didn't have to move it around the window more than a 1/2 inch. Being a ex mechanic I've got probably a dozen small to medium pointy picks, stick them in hole and use pick as a lever to move things around. Maybe we lucked out but didn't take 15 mins.. Oh yeah, would have been great if when removing you marked the holes that needed rivets, otherwise you may need to hold up the trim pieces to decide where the first layer of rivets goes. I'll see if I have any pics...
Good luck, Mark D.
mrdes8 is offline   Reply With Quote
Old 04-15-2021, 02:33 PM   #6
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
Good luck, Mark D.
Ok, so there is a trim piece that holds the endcap to the window flange? That's all I'm really asking. All my other holes align at the rib and the fit is better now that I removed some insulation.
Old 04-15-2021, 02:44 PM   #7
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Hope this helps, obviously only goes one way...
Mark D
Old 04-15-2021, 02:48 PM   #8
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Okay, yes there are trim strips around the window. I did not reuse the originals which I seem to remember being plastic as opposed to metal around all the other windows... You got it....
Mark D
Old 04-15-2021, 03:43 PM   #9
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
ID:	393286. I've got it in now! Seems to be ok.
1969 Safari Rear FIberglass Endcap, sink and tub. - Oregon Vilnutz Airstream Classifieds 0 12-30-2020 09:09 AM
ISO 70's fiberglass endcap, side awning, bathroom part, thermostat cover SELLING front/back window awnings tarynhofert Airstream Classifieds 0 07-14-2020 09:07 AM
Overlay or replace the fiberglass endcap? mmeans Interior Restoration Forum 7 04-11-2015 02:03 PM
Painting the fiberglass endcap barbaralyn Interior Restoration Forum 7 03-26-2015 09:50 AM
Reinstalling fiberglass interior endcap - holes not aligning Airwave503 Ribs, Skins & Rivets 6 02-02-2015 08:03 AM
