Old 09-24-2023, 10:48 AM   #1
2016 19' Flying Cloud
Deerfield Beach , Florida
Panoramic window curtains
2 vs 4 panel curtains, pros and cons,? Deciding for new pleated curtains.
dominicjohn is offline   Reply With Quote
Old 09-24-2023, 12:24 PM   #2
2007 16' International CCD
Somewhere , Colorado
Based on our experience with a double panoramic window trailer, we would definitely do four panels. We love the flexibility to be able to selectively block a bright light or an eyesore without blocking the good views.
Here is a great idea — which we used — for improving the look and function of these curtains. This would be super easy to do while replacing the curtains.
https://www.airforums.com/forums/f39...nt-214754.html
field & stream is online now   Reply With Quote
Old 09-24-2023, 01:07 PM   #3
wnew1130's Avatar
2023 25' Flying Cloud
1992 29' Excella
1976 25' Tradewind
2003 36' Land Yacht XC Diesel 300 hp w/2slides
Anacortes , Washington
Another reason for four panels
The four panel curtain is a throwback to pre-A/C Airstreams.
If you choose not to use the A/C, you open the middle section of the panoramic window to the first (smallest) opening, turn on the Fantastic fan to exhaust, and close the curtains. Then you adjust the amount of cool, incoming breeze by spreading apart the two outer curtain sections from the middle section. This works extremely well if your bed or beds are under the window, as each opening can be adjusted to lessen or increase the breeze for the “hot” or “cold” sleeper. And the closed curtain over the opened middle window maintains visual privacy at night.
wnew1130 is offline   Reply With Quote
Broken Panoramic Window dosky Windows & Screens 7 02-15-2007 12:56 PM
