I am sorry that I just saw this post.
Have you painted yet?
I am sure that you have, and I am not sure if you can still get oil based paints, but if you did get a hold of some, yes, it will turn Yellow.
I am in the process of also painting my whole inside of my Land Y, all in an warm off-white. but I am sanding and also using Krud Kutter Gloss-Off to prepare the surfaces before painting, there is no need to prime if you are using a Behr or Marquis Paint and Primer in one, saves you the step of priming.
