Old 09-03-2007, 04:47 PM   #1
Nellie's Avatar
Gabriola , BC
Painting fake wood
Hi all. This question may have been answered elsewhere but I couldn't find it. I am wondering if I can paint the fake wood surfaces in my 73 Overlander? I am beginning a restoration and would like to brighten it up a little. Even the fridge has a fake wood door which is horrible. Do they make stainless steel fridge doors that I could replace it with? Just a thought.
Nellie
Nellie is offline   Reply With Quote
Old 09-03-2007, 05:21 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
My PO used a gel stain to recoat my trailer and give it a wood grain look - it resembles wood from across the trailer, and up close still looks ok. I think I could have done a better job with the stain, and you may too.
Good luck,
Dave
Fyrzowt is offline   Reply With Quote
Old 09-03-2007, 05:28 PM   #3
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Not a good idea...
If you search for "paint" and "fake wood" you may find several threads on the subject.. It may be possible to darken lighter colors, but lightening the dark "fake walnut" is usually a bad idea. The fake wood is really a vinly paper held on with adhesive, and the paint chemicals can cause the adhesive to fail even more than it usually does with age, resulting in a blotchy painted bubbly contact-paper look...
Options include doing real strip and then painting surface under fake wood, or applying new fake wood over cleaned sub-surface...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 09-03-2007, 05:51 PM   #4
Retired.
. , At Large
They do make stainless steel finish fridge doors, unfortunately they come attached to refrigerators. Maybe you could put in some lighter trim, it would help.
Old 09-03-2007, 06:52 PM   #5
Nellie's Avatar
Gabriola , BC
Ha-ha I guess that was a dumb question about the fridge door. Maybe I'll just replace the whole fridge one day, but it works fine so I guess I'll live with it for now. So it seems the consensus is not to paint over the fake wood, am I right? Maybe I'll try some new curtains and stuff first- I just find the overall look a bit boring at this point. And I hate fake wood. Ugly, ugly stuff!
Old 09-03-2007, 07:38 PM   #6
Road Ruler's Avatar
Images: 38
We too had fake wood on our 73 Dometic door. It was easy to upgrade with a piece of aluminum. I used a piece of Alcald I had left over from a project.
Took about an hour to prepare and install. I still need to paint the orange trim a charcoal grey. That may happen soon. It was worth the effort, a huge improvement.
Pic of fridge door... http://www.airforums.com/photos/show...500&userid=682
Old 09-03-2007, 07:44 PM   #7
Nellie's Avatar
Gabriola , BC
Ooh! That looks great. I will have to try that. Thanks.
Nellie
Old 09-03-2007, 07:46 PM   #8
cameront120's Avatar
1972 25' Tradewind
For the fridge door you can have a piece of stainless laminate (from Formica or Nevamar or Wilsonart) cut to size and cover the old wood grain stuff. I haven't lloked at my fridge closely, but it may be a simple matter or removing the trim and removing the existing piece of laminate and replacing it with the new. If not, just use contact cement to adhere the new onto the old.
If you have a Windsor Plywood near you, they'll have these laminates. I think Rona carries them as well.
For covering the fake wood, it might be worth trying to prime and paint the stuff and see how ell it stands up. Perhaps a melamine paint would do the trick?
North Vancouver, BC
Old 09-03-2007, 07:48 PM   #9
2004 16' International CCD
1997 25' Safari
hamilton , Montana
Road Ruler,,, did you slip out the existing fake wood panels,, use them for a template,, and then what did you use for an adhesive?? i have a fake wood fridge also in the Safari,, would love to use copper or aluminum sheeting,, thanks,, great job,, looks wonderful,, donna
dieterdog is offline   Reply With Quote
Old 09-03-2007, 07:53 PM   #10
dudebb's Avatar
1962 16' Bambi
Newtown Square , Pennsylvania
I saw on one of the DIY shows that there is a stainless contact paper type of product that was used to cover the door on a refrigerator in a house they were "staging" to sell. Perhaps Lowes or Home Depot type stores would have it.
George
1962 16' Bambi (sold )
1996 Buick Roadmaster Estate Wagon
Airforums# 7906, WBCCI #4248, WDCU
dudebb is offline   Reply With Quote
Old 09-04-2007, 07:30 AM   #11
Road Ruler's Avatar
Images: 38
Yes Donna, The door trim is easy to remove with just a screw driver. Only need to remove a couple if I recall. We used the old panel as a template to cut the new aluminum to size.
George's idea will work too. We experimented with stick on aluminum mac tac on some areas in the trailer with favourable results. The real metal does look better though.
Of all the improvements we made with our unit this one gave us the biggest bang for the buck in the shortest amount of time.
Old 09-04-2007, 08:29 AM   #12
mandolindave's Avatar
What about putting wallpaper over the fake wood walls?
mandolindave is offline   Reply With Quote
Old 09-04-2007, 09:42 AM   #13
Blu_Hwy_Lady's Avatar
1972 23' Safari
Placitas , New Mexico
Absolutely paint that fake wood
I painted my fake wood in my '72 Safari and it made a huge difference. I also ripped out the bulkhead divider and had new fronts made for the cabinets out of nice birch. However, in part one of my renovation I even painted some of the tambours and that worked out find. The secret--which I learned here on the Forums-- is Sherwin Williams Bonding Primer. You can get paint to stick on wood with that stuff. I faux painted everything else including the walls and endcap....and yes the front of the fridge. I went to the Southwest Vintage Camper Association rally a couple of weeks ago and there was a woman from Texas who did some really nice stuff in her Airstream with wallpaper that was torn into kind of like large mosaic pieces that she put on her end cap. I know it sounds weird but it looked fantastic. Anyway, here's a picture of my interior:
Name:	'72 Safari_interior.jpg
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
Blu_Hwy_Lady is offline   Reply With Quote
Old 09-04-2007, 10:37 AM   #14
Nellie's Avatar
Gabriola , BC
All great ideas, thanks, and your airstream looks great Susan. I was having a lot of trouble coming up with ideas, and now I have something to work with- this is a great forum! I really found all that dark fake wood made it claustrophobic. Now I can't wait to get going. Of course I have to finish sealing the outside first, but once that's done... I will have to wait until spring now to buff and polish, anyway, so will spend the winter on the inside.
Old 09-04-2007, 11:02 AM   #15
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
I to have the cardboard wood grain look front on my frig. I was going to Home Depo to see what type of Alumn sheeting they have. A lot of the older home frigs, ovens, stoves, dishwashers have removeable fronts. I was going to check with someone who has old appliances and see if they have removeable fronts that I may cut and fit my frig. I know our old horse trailer frig I took the front off and covered it with Route 66 wall paper it really looked great, although the front was metal not cardboard. Keep us posted on what you end up doing.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 09-04-2007, 11:22 AM   #16
pamelake's Avatar
1974 25' Tradewind
Lake Oswego , Oregon
For the fridge in my '74 Tradewind I used the laminate used on my counter tops... just removed the panels on the front of the fridge by removing the screws in the little strips of plastic with the Dometic name on it... cut the correct size laminate and vioila!
Name:	New Cabinets 006.jpg
pamelake is offline   Reply With Quote
Old 09-04-2007, 05:23 PM   #17
1972 23' Safari
Another idea for the front of the fridge are these squares that are supposed to look like the old pressed tin ceiling tiles. They're plastic but they really look like metal. They are exactly the right size to put 2 of them on the front of the fridge. I really considered doing that with mine because they are so cool, but decided it might be too busy with the rest of the stuff I was doing so I just faux painted it to match the fake wood faux painting. The tiles were at Lowe's and it seems like they were $8.
Old 09-04-2007, 09:36 PM   #18
Nellie's Avatar
Gabriola , BC
Wow- I'm so glad I joined this site. I was having a really hard time getting inspired, and now I'm all gung-ho! My husband kept telling me that it should be kept original for resale value, but it seems that isn't true- am I right? I don't think the resale value is great on this model anyway (73 Overlander- rear bathroom) so I might as well pretty it up as best I can. I think it would have to be in pristine shape to be worth keeping original, and it definitely isn't, inside or out. Do you agree?
Nellie
Old 09-04-2007, 10:21 PM   #19
Nellie's Avatar
Gabriola , BC
Oh, and just so y'all know, this was my husband's trailer before I even met him. He bought it in the late 90's for $1000. and lived in it for a year in Whistler, B.C. while he was working there. He brought it to the island with him in 2001 and it has sat in his yard ever since, sadly neglected. I came along in 2002, but we did little with it for several years apart from me cleaning the inside every spring. We mostly just used it for overflow storage and a spare bedroom for my son's friends occasionally. It didn't leak until about 2 years ago when he pressure washed it (bad mistake, I know). Now I am starting to appreciate what a cool thing it is, and would love to make it not only useable but beautiful again. We have been offered up to $8000.00 for it, even in the deplorable condition it is in, but have never been able to part with it. Maybe we're crazy, but I guess we love the big ol' thing. My dream is to see it parked permanently on a lakeside lot somewhere.....
Nellie
Old 09-14-2007, 03:38 PM   #20
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used the aluminum metal wallpaper, and it looks good, although if I was to do it over I would use additional contatct cement as mine bubbled up on some spots, and had to be reglued. I covered the vinyl walls the p.o. had painted.
Its aluminum with a small pattern on it embossed.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Fake Ad on eBay ColdEspresso Dollars & Cents 15 08-22-2007 09:19 PM
Fake Excella? Becky B. Clearcoat, Exterior Paint & Trim 59 06-26-2007 02:29 PM
Tambour Wood or Fake? The Flintstones Cabinets, Counter Tops & Furnishings 2 05-18-2007 01:44 PM
Painting info for 70's wood grain panels Road Ruler General Interior Topics 17 02-03-2007 07:48 AM
how to get like new, the fake-wood laminated panels ? brunoffrance Upholstery, Blinds, Walls & Interior Finishes 9 05-21-2006 07:25 AM
