Old 02-27-2019, 09:46 AM   #1
Original Wood Closet Linings?
Hey Everyone!
On my 1984 Motorhome I have wood linings in some of the closets, that I believe might be cedar?
I have, and have had a leak in the roof or upper bodyside that has run down the wood, staining it, and collecting on the floor. I am working to find and resolve the leak this week.
I have questions:
1/ Is it real wood?
2/is it applied over the inner aluminum skin, or a ply instead of the aluminum skin?
3/ How have others refinished this wood?
Thanks in advance!
Old 03-03-2019, 10:17 AM   #2
Anyone???
Old 03-03-2019, 10:27 AM   #3
2007 22' International CCD
If it’s cedar, at most you could sand it lightly to restore the smell and moth repellent ability. There are oil finishes made particularly for cedar. Varnish or other sealing finishes should not be used because they seal in the volatile oils that make it work. If it’s stained from water, it’s real wood.
Old 03-03-2019, 10:57 AM   #4
Thanks!
The wood looks to be uncoated...
I assumed that all Airstreams had the wardrobes like this...
Maybe I'm wrong?
Could it be a veneer over the normal aluminum interior skin?
Old 03-03-2019, 10:31 PM   #5
Nary a clue here. My 2007 Wardrobe is lined with laminate on the sidewalks and the aluminum interior in the back of the closet.
Old 03-04-2019, 04:29 AM   #6
sandlapper's Avatar
1993 34' Excella
York , South Carolina
It is Cedar veneer on thin plywood.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 03-04-2019, 07:51 AM   #7
Mollysdad's Avatar
There was a great thread a while back about installing cedar planks in an AS wardrobe.
http://www.airforums.com/forums/f46/...ng-184354.html
Old 03-04-2019, 01:54 PM   #8
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
As John said, it is indeed Cedar. If you want to replace it, Van Dykes Restorers
https://www.vandykes.com/?gclid=EAIa...SAAEgIoD_D_BwE
is a good source for adhesive backed cedar veneer. Another option is to use Cedar Oil to "refresh" the veneer. You can find that at any good wood working store.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-04-2019, 04:01 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by Aviator View Post
... Another option is to use Cedar Oil to "refresh" the veneer. You can find that at any good wood working store.
That's what I did in my Excella. Got the Cedar Oil off eBay. Worked great.
Vaughan
Old 03-09-2019, 02:36 PM   #10
Thanks Peeps!
Will get some Ceder oil for sure!
So, is the ceder faced ply put OVER the aluminum interior skin, or is it in place of it??
Old 03-09-2019, 05:02 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
The wood is eastern red cedar, not western cedar. The eastern red has the aroma that repels insects.
When there was a leak in my closet I sanded it to remove the stain. A light sanding will also bring out the aroma.
The plywood is installed over the aluminum interior skin. I can't tell how it is fastened by looking, but I assume it is glued in place
If it has to be replaced:
This is similar to what is in my 99 Excella.
https://www.homedepot.com/p/Columbia...E&gclsrc=aw.ds
This is another option>
https://www.homedepot.com/p/1-4-in-x...E&gclsrc=aw.ds
The cedar oil>
https://www.homedepot.com/p/Giles-an...L008/203522859
Alan
Replacing fake wood with real wood webspinner General Interior Topics 65 04-03-2013 09:13 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
Replace linings or not Bill C. Brakes & Brake Controllers 5 02-19-2008 10:11 PM
Original wood grain laminate (74) AV8 Upholstery, Blinds, Walls & Interior Finishes 1 01-19-2004 08:33 AM
