Old 12-18-2023, 06:18 PM   #1
1999 28' Excella
New Orleans , Louisiana
Mouse fur cleaning?
My walls need to be professionally cleaned. What would anyone suggest?
thanks
badkat is offline   Reply With Quote
Old 12-18-2023, 06:35 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I have used Simple Green in a Bissell Little Green Machine on mine with good results.
CRH is offline   Reply With Quote
Old 12-19-2023, 01:19 AM   #3
Boxite's Avatar
2008 22' Safari
When we bought our 22’ Safari Sport it had a few serious spots/areas of dark stain which I first thought looked like where the aluminum table trim had “smudged” against it…. but I later decided was maybe mold from condensation on the interior walls. As I looked around the walls and ceiling I found other places also. I had no faith in getting it clean.
But I remembered a product I’d used on some aircraft carpet and tried it on the mouse fur and it worked beautifully.
It is “Spot Shot” and comes in an aerosol can. I used my wet/dry shop vac hard-nozzle and, as I sprayed the spot generously with the Spot Shot…I followed along immediately with the vac sucking up the aerosol almost as soon as it soaked the fabric. VOILA!
Sold at WalMart, Amazon, etc.
Old 12-19-2023, 04:47 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I used Foley carpet spot remover and a Little Green Machine to clean the mouse fur. It did a great job.
First I used the machine to run warm water through the fur to get the initial dirt out and to moisten the fur, then spray with the Foley. After letting it sit for a few I used a soft sponge to sort of scrub the fur, then hit it again with the machine to extract the cleaning solution and the moisture.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 12-19-2023, 03:18 PM   #5
1999 28' Excella
Great ideas, thanks!
Old 12-20-2023, 08:34 AM   #6
1988 32' Excella
Robbinsville , New Jersey
A recent thread saying that Simple Green causes corrosion of aluminum.
https://www.airforums.com/forums/f44...en-248443.html
Old 12-27-2023, 05:21 PM   #7
Nashua , New Hampshire
I recently had to deal with a mold issue on an upholstered, foam-backed wall and some wood framing, and it's not as difficult as I feared during my initial panic.
Plain ol' white vinegar kills mold, so I sprayed the area generously. Afterward, I hit it with a steamer, which removed the staining, much like a carpet cleaner would. Once I was satisfied that the mold was dead and gone, I ran a fan for several hours to make sure the area was completely dry.
By that point, the vinegar smell had reduced to the point that we barely noticed it and within a day or two it was completely gone. So, you don't have to worry about your camper smelling like a salad.
Bnystrom is offline   Reply With Quote
cleaning ugly mouse fur! badkat Upholstery, Blinds, Walls & Interior Finishes 7 02-16-2022 02:04 PM
Mouse fur cleaning AWCHIEF Upholstery, Blinds, Walls & Interior Finishes 25 01-27-2018 12:24 PM
Mouse fur professional cleaning? badkat Upholstery, Blinds, Walls & Interior Finishes 13 07-31-2016 08:06 AM
cleaning mouse fur MontyV Upholstery, Blinds, Walls & Interior Finishes 2 07-12-2013 07:11 PM
Spot cleaning or replacing mouse fur flyslinger Upholstery, Blinds, Walls & Interior Finishes 6 07-08-2012 08:30 AM
