Old 01-17-2019, 06:58 PM   #1
Whistler , British Columbia
End Cap Cracking (HELP)
Hi there,
Both my end caps have this "tear" at the corner where the cabinets meet the plastic. My plan is to paint the end caps. Does anyone have any tips to fix these cracks/tears?
Thank you
T
TylerG is offline   Reply With Quote
Old 01-17-2019, 07:03 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
First drilll a hole at the end of the crack to keep it from running. I would then try a paste epoxy to fill the crack.
Old 01-17-2019, 07:12 PM   #3
Al Zeppelin's Avatar
1949 22' Liner
St Petersburg , FL
Are the cabinets secured? Looks they are pulling off of the wall and taking the plastic with it.
Al Zeppelin is offline   Reply With Quote
Old 01-18-2019, 06:53 PM   #4
That's a great question. I will have to take a look. I am not sure how the cabinets are secured. Is this something you can see from opening the cabinets or would I have to remove the nose cap(Not something I hear is easy to do)?
Old 01-18-2019, 08:21 PM   #5
rideair's Avatar
Looks to me like the cabinet has pulled it away. I would remove the cabinet to relieve the pressure or figure a way to push it back up in place, then do what others stated about drill a small hole at the end of the crack to stop it from getting bigger and epoxy.
Good Luck
Paul Waddell
rideair is offline   Reply With Quote
Old 01-21-2019, 06:59 PM   #6
Originally Posted by rideair View Post
Looks to me like the cabinet has pulled it away....
Good Luck
I have taken a look and I think the cabs are floating. Attached only to the nose cap. Is there anyone that could confirm how they attached the cabs in the nose caps of a 90's airstream??? For me to really take a look I would have to completely remove the nose cap which for obvious reason have little interest in doing if I am correct about how they are mounted.
Does anyone know what the nose caps are made of?
Old 02-24-2019, 08:08 AM   #7
1994 30' Excella
Mississauga , Ontario
I've read elsewhere on the forum that they are made of ABS plastic. What I would like to know is what is behind the end cap. Is there an aluminum skin back there or just the frame of the trailer?
Al
Al and Jean
BRN 3845
TAC ON-3
Old 02-24-2019, 11:42 AM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Al
In general there is no frame or interior skin to support the exterior end caps. I am not sure if the interior end caps have their own support frame but I doubt it and think they are probably free floating.
Old 02-24-2019, 04:24 PM   #9
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
I had this problem and hear it is common. I stop-drilled, filled with some Kwik epoxy, riveted small aluminum reinforcement patches over the cracks and painted them. Color doesn’t exactly matches, but the cracks haven’t grown in about 5 years.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 06-08-2019, 11:20 AM   #10
1995 30' Excella
Harper Woods , Michigan
It appears that the first job is to stabilize or remove the cabinets. After that, there is All-Purpose Bondo for wood and other materials that would probably do well for repairing the crack. You can see in another thread where I rebuilt the corners of the skylight garnish/bezels with the Bondo. It worked very well.
http://www.airforums.com/forums/f39/...ml#post2125575
Bob Blarney is offline   Reply With Quote
Old 06-19-2019, 09:28 PM   #11
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
I have removed my rear end cap and am working on a solution to structurally support the cabinet. It's a very poor design. The cabinet is only supported by the plastic...that's the problem.
Steve
Steve Bryant is offline   Reply With Quote
Old 06-19-2019, 09:38 PM   #12
1991 34' Limited
Wichita , Kansas
Here are some pictures.Click image for larger version
ID:	343870Click image for larger version
ID:	343871Click image for larger version
ID:	343872Click image for larger version
Steve
Old 09-09-2019, 11:07 PM   #13
1991 34' Limited
Wichita , Kansas
I finished febuilding/improving my end cap and I'm pleased with the results. I'll do a thread on the details later.Click image for larger version
ID:	351820Click image for larger version
ID:	351821Click image for larger version
Steve
Up on the roof and noticed cracking sealant Getahobby Roof 5 08-04-2012 08:54 AM
Trouble with Sansui TV case cracking russ240 Sprinter and B-van Forum 6 08-03-2012 09:13 AM
Tires Cracking - Any Suggestions NavyDavesCvl Tires 10 03-28-2010 03:43 PM
Cracking end cap 76 Tradewind Siamese66 General Interior Topics 2 10-19-2006 06:27 AM
Rear Bath Upper Wall Cracking w5wi General Interior Topics 0 07-20-2003 09:13 AM
