Old 03-21-2023, 11:13 AM   #1
Vancouver , BC
Question Drywall Mud Skim Coat on Aluminum Walls - Terrible Idea?
Hi All! I am a first time poster but longtime reader. My wife and I are renovating our 2001 Safari 27' and just recently removed the carpet mouse walls. We are now having a hard time deciding what to do with the walls. Our first idea was to just use wall paper, but after reading the helpful posts on here, it sounds like this is not a great solution as it will not adhere to the aluminum. Our second option was to clean the glue and prime + paint, but the glue has proven very difficult to remove. We tried using acetone with a razor blade and it was SLOW.
Our friend (who also has an Airstream) suggested using a lite drywall compound to do a skim coat, and sanding it smooth. Is this a terrible idea? Will it crack and fall apart as soon as we start bumping down the highway?
Thanks!
Mtaggart is offline   Reply With Quote
Old 03-21-2023, 11:30 AM   #2
dznf0g's Avatar
Oswego , Illinois
Not a good idea.
-Rich-
Old 03-21-2023, 12:14 PM   #3
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
The aluminum will expand and contract a lot more than the drywall compound, which is very stable. The result will be loss of adhesion.
Brian
ITSNO60 is offline   Reply With Quote
Old 03-21-2023, 12:24 PM   #4
2017 25' International
West Lake Hills , Texas
…And all that bouncing will crack the mud.
Could you sand off the glue then buff the aluminum? Maybe a series of fiber and fiber flap discs.
Fungus is offline   Reply With Quote
Old 03-21-2023, 02:01 PM   #5
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Chuckey , Tennessee
Images: 108
Yes, it's a bad idea. Yes, it will not adhere to the aluminum and flake/chip off. I don't think it would even take "bumping down the highway" just the heat/cold cycles inside the trailer.
You could spray a textured epoxy paint that was used in vintage trailers called Zolatone. We sprayed it in our trailer almost 15 years ago, it went over various surfaces (bare aluminumn, previously painted aluminum, plastic trim pieces) perfectly and still looks 'like new' today. I have also seen where it was sprayed over the vinyl wallcovering in a 60/70's trailer - it looked great! It's thicker than "normal paint" so would hide imperfections from the residual glue.
There are several different formulations, of Zolatone - the kind I am talking about is the '20 Series' meant to go on metal - it's what they use in industrial/marine/automotive applications - it's not cheap, but it's awesome!
Shari
RMVAC | ACI - CO (CAC) Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 03-21-2023, 02:47 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 199
Drywall Mud Skim Coat on Aluminum Walls -- Terrible Idea?
Greetings Mtaggart! Welcome to the Forums as a poster!
Thanks!
Dry Wall Compound does not like movement as others have posted. It will not take kindly to the large fluctuations in temperature in your Airstream, particularly when combined with the expansion and contraction of the aluminum. The vibrations of the first trip, even with perfectly balanced running gear and the smoothest of hitches, cracks and/or delamination would begin.
I live near the New Madrid Fault, and we have mild "tumblers", earthquakes that aren't sever enough to wake one when sleeping, but they are enough to crack Dry Wally Compound on any number of joints where the movement is concentrated.
I wish that I could make a suggestion for a solution, but I can't think of any. The adhesive residue needs to be removed before about anything else can be done. The one thing that did occur to me was the possibility of using one of those mild abrasive wheels designed to be mounted in a drill to remove decals from autos, but those are so small that it would be slow going with the interior wall surface of an Airstream.
Good luck with your project!
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 03-21-2023, 03:14 PM   #7
ChristyB56's Avatar
Waynesville , Georgia
Wall treatment
We stripped Zolatone and mouse fur from our ‘63 Overlander walls and I used a rotary sander and made circles. Kind of a hippie type vibe but it worked out OK. Covered the rough mill finish aluminum nicely. Sorry photo is wonky, I’m on old iPhone.
ChristyB56 is offline   Reply With Quote
Old 03-21-2023, 03:28 PM   #8
SlowPokePete's Avatar
2020 25' Globetrotter
Hillsdale , New York
That looks pretty cool to me!
SPP
SlowPokePete is offline   Reply With Quote
Old 03-21-2023, 05:19 PM   #9
ChristyB56's Avatar
Walls
Thank you! Was actually fun to do.
1963 Overlander “Meraki"
Frame off resto-mod 2018-2023
Waynesville, Georgia
Old 03-22-2023, 05:51 PM   #10
PC Conner's Avatar
2018 27' Flying Cloud
INDIAN HARBOUR BEACH , Florida
Very good. Creative, harmonious, only cost is labor!
PC Conner is offline   Reply With Quote
Old 03-26-2023, 05:37 PM   #11
1976 25' Tradewind
Shelton , Washington
In my opinion your best solution would be to strip the walls down to the aluminum and then polish, looks great and no need to worry about paint or other products coming off due to expansion and contraction of the aluminum. Its not to hard to strip using paint striper, let it sit for a bit and than carefully scrape off with a plastic scraper. Comes right off, just be patient. Good luck with your project.
Before and after striping the walls.
https://youtu.be/2cnM7EYRZGg
https://youtu.be/Ko3hlFuSLtc
Toolmanbt is offline   Reply With Quote
Old 03-27-2023, 10:42 AM   #12
Steamguy's Avatar
2024 19' Caravel
Washougal , Washington
Something to consider, once you get the walls 'clean'.
There are sign outfits who do 'wraps' on trucks, cars, vans, and so on. They can do your interior in a plain color for not a lot of money. Best part is, if you want to change it, it can be redone in a similar amount of time.
I'm considering having the hood and roof done on my 20-year-old pickup where the clearcoat has failed, and have been checking with a few outfits as I get time.
Steamguy
2024 Caravel 19CB
"Dot"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Protecting Plasti-coat / Clear coat John&Vicki Exterior Restoration Forum 5 07-30-2019 07:37 PM
remove clear coat and re coat one panel at a time. Bill M. Clearcoat, Exterior Paint & Trim 7 08-01-2016 02:37 PM
clear coat or plastic coat fpoulson Cleaning, Stripping & Polishing 1 10-26-2014 12:42 PM
Mud Dauber protection idea Vycan Classic Motorhomes 8 03-22-2014 11:03 AM
Removing paint and skim coat 67twinkie Upholstery, Blinds, Walls & Interior Finishes 12 12-20-2010 02:38 PM
