Old 12-06-2022, 06:30 PM   #1
1990 29' Excella
baltimore , Maryland
Cleaning vinyl coated aluminum...
What is the best cleaning solution to clean and not damage the vinyl coated aluminum interior?
Same question about the plastic front/rear endcaps.
Thanks!
groundhogy is offline   Reply With Quote
Old 12-06-2022, 08:11 PM   #2
1972 25' Tradewind
St Clair County , Michigan
Early Dawn
I just used Dawn detergent and warm water and a soft brush. The vinyl coated aluminum panels are pretty indestructible and it's a good thing because that sticky coating does not come off easily. The plastic end caps however can be a bit fragile, so be gentle with them.
What is that sticky coating? I don't think anyone knows and it does come back.
TR Anderson is offline   Reply With Quote
Old 12-06-2022, 08:44 PM   #3
1990 29' Excella
I personally think the sticky feeling is just cooking oil that condenses on the surface
Old 01-06-2023, 09:31 AM   #4
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Send a message via Skype™ to Erik Olson
We use Method cleaner, Magic Eraser (lite formula version), bamboo paper towels, hot water wipe on the walls. Spray, allow to soak on surface, magic eraser, then bamboo towel wetted in hot water.
Erik Olson
1974 Ambassador 29' Ohana
www.overlandfilmstudios.com
Erik Olson is offline   Reply With Quote
Old 01-10-2023, 01:19 PM   #5
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Chuckey , Tennessee
Images: 108
The "sticky coating" is actually the vinyl wallcovering off-gassing and deteriorating. Then the stickiness attracts airborne "gunk"....early plastics at their best! Once the vinyl is thoroughly cleaned, it can be coated with clear Future/Pledge floor finish. It helps to encapsulate the vinyl and keep the stickiness at bay.
Shari
ACI - East Tennessee Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-10-2023, 11:48 PM   #6
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Krud Kutter mixed with warm water will take off the stickiness. A light coat of Mop n Glo or Future liquid wax will keep the stickiness from returning.
4RXLA is offline   Reply With Quote
Vinyl coated interior skin source? daved20319 Ribs, Skins & Rivets 6 01-23-2015 07:33 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
Pre-coated Alcoa aluminum panels idahosafari Ribs, Skins & Rivets 4 12-06-2004 04:33 PM
Painting the vinyl coated... geof Upholstery, Blinds, Walls & Interior Finishes 1 04-28-2003 10:37 PM
