Old 03-03-2024, 08:17 AM   #1
2023 27' Globetrotter
2001 34' Limited S/O
Florence , KY
Cleaning Mouse Fur
Hello,
I may not be searching in the right area but wanted to get some advice on general cleaning of mouse fur.
We have a trailer with mouse fur. It is in pretty good shape, not particularly stained with dust nor peeling off the walls. I would like to clean the entire interior.
From what I read, possibly the diluted bleach mixture spray, let sit, dry, then vacuum?
Also, any advice on the vinyl for the same reason would be appreciated. I am wanting to avoid creating any new issues since it looks pretty good.
Thank you!
Stark61 is offline   Reply With Quote
Old 03-03-2024, 08:31 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
This is what I used:
https://www.homedepot.com/p/Folex-1-...R128/202820335
Put it in a spray bottle, spray a small area and then gently brush it in, and while still damp use a small hand-held carpet cleaning machine like a Green Machine and suck out the dirt using just warm water in the tank.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 03-03-2024, 09:07 AM   #3
2024 28' Flying Cloud
2004 25' Safari
Boston , Massachusetts
On my 2004 I carefully removed a section or 2 of mouse fur and put it in the washer, warm wash with Oxy Clean Delicate cycle. I had no problem with with the shape changing and it did a good job. To reattach I used velcro strips with adhesive to hold mouse fur in place. In the package are 2 strips only one side works. Apply it to the seams or where ever you need adhesion on the bare wall. Press the mouse fur against it and done. I used a plastic putty knife to tuck it back under the plastic seams. Good luck with your project.
FLY28 is offline   Reply With Quote
cleaning ugly mouse fur! badkat Upholstery, Blinds, Walls & Interior Finishes 7 02-16-2022 02:04 PM
Mouse fur cleaning AWCHIEF Upholstery, Blinds, Walls & Interior Finishes 25 01-27-2018 12:24 PM
Mouse fur professional cleaning? badkat Upholstery, Blinds, Walls & Interior Finishes 13 07-31-2016 08:06 AM
cleaning mouse fur MontyV Upholstery, Blinds, Walls & Interior Finishes 2 07-12-2013 07:11 PM
Spot cleaning or replacing mouse fur flyslinger Upholstery, Blinds, Walls & Interior Finishes 6 07-08-2012 08:30 AM
