Old 03-08-2018, 04:04 PM   #1
DilmoreFarms's Avatar
1984 31' Excella
brandon , Mississippi
Ceiling and Walls (Can't handle spray paint)
I have read many many posts about the use of Krylon Spray Paint for the plastic end caps. I am wanting to paint the ceiling and walls in my 84 Excella. It appears to be a vinyl glued to the walls.
Has anyone primed the walls with Bin Primer then used Interior house paint?
The vinyl does have a web like pattern in it, and I would like that to go away.
Any suggestions?
DilmoreFarms is offline   Reply With Quote
Old 03-08-2018, 04:11 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Bus Kote can be used as an interior paint. Never heard of anyone doing it but the company says it will help with heating and cooling. (just finished doing my roof) You may also be able to buy the ceramic insulating particles to add to other paint.
Old 03-08-2018, 07:11 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Your on the right path. Here what I'm using.Click image for larger version
ID:	305959 the directions says you can topcoat with latex
Matt
rugjenkins is offline   Reply With Quote
Old 04-25-2018, 07:33 AM   #4
1984 31' Excella
It worked
Binz primer, then really good paint from lowes, primer and paint all in one. and it looks great!
Old 04-25-2018, 11:12 AM   #5
rugjenkins's Avatar
1975 Argosy 28
Did you paint the skins? Post a pic. I just finished ours. Now it's all white, crisp and clean looking.
Matt
Ode To a Can of Silver Spray Paint... 911Patriot Airstream Lifestyle 4 08-20-2014 10:09 PM
Can ABS walls/ceiling on vintage AS be replaced? blkmagikca General Repair Forum 1 08-17-2014 11:05 PM
Can ABS walls/ceiling on vintage AS be replaced? Ssmookler Interior Restoration Forum 0 08-17-2014 11:18 AM
Sunburn or spray paint? Tabasco Cleaning, Stripping & Polishing 10 05-24-2012 10:01 AM
Can I just spray-paint a window screen? Chuck Upholstery, Blinds, Walls & Interior Finishes 9 07-08-2004 10:24 AM
