Old 04-18-2018, 08:00 AM   #1
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Brittle plastic trim
The 40+ yr old plastic trim that runs on the outer edge of the interior aluminum panels and end caps is very brittle and has either fallen off or chipped in many places. What has everyone used as a replacement or alternative?
Supply sources and pictures appreciated!Click image for larger version
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 04-18-2018, 09:08 AM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Krylon makes a paint specifically for plastics that does a pretty good job of protecting old plastic. I doubt it has a restorative effect but it definitely improves the look.
DryFly is offline   Reply With Quote
Old 04-18-2018, 09:26 AM   #3
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
...and likely wonít regenerate the broken pieces )
I forgot to add that I plan to use Krylon to repaint the end caps and strip the vinyl down to the bare aluminum and leave it that way. So Iím looking for something that will visually look good with the aluminum.
1975 Argosy 26
1979 Argosy 30
Old 04-20-2018, 10:18 PM   #4
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I used frp trim. My wall will be white not aluminum though
Matt
rugjenkins is offline   Reply With Quote
Old 04-21-2018, 06:06 AM   #5
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Thanks! Exactly what I was looking for!
1975 Argosy 26
1979 Argosy 30
Old 04-21-2018, 07:28 AM   #6
1970 23' Safari
Marion , New York
Vintage Trailer Supply sells that trim. Look under interior mouldings.
DremStremer is offline   Reply With Quote
Old Cracked and Brittle Counter top trim palmtreegirl Cabinets, Counter Tops & Furnishings 4 09-12-2011 01:25 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Red plastic trim insert for 1978 International... drboyd Clearcoat, Exterior Paint & Trim 2 09-17-2003 12:47 PM
replacement plastic trim 74Sovereign General Interior Topics 1 09-10-2002 10:44 AM
