Old 01-19-2018, 06:08 AM   #1
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Advice on dinette cushions
After building a custom dinette to replace my front gaucho, I had bottom cushions made to fit the seats (one long cushion on street side and shorter one on curb side due to the door). I have decided to make the back cushions 16 inches tall but am wondering about lengths. Street side total length is 79 inches and curb side is 48 inches.
Options:
1. Make full length back cushions: 79 inches and 48 inches
2. Make curb side full length (48 inches) and split street side into two cushions, 48 inches and 31 inches.
3. Split curb side into two 24 inch cushions and street side into three cushions, 2 @ 24 inches and 1 @ 31 inches.
There is storage space under the benches but it is rarely accessed. I plan to affix the back cushions in place using Velcro.
Opinions?
BambiTex is offline   Reply With Quote
Old 01-19-2018, 07:46 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If you affix the cushions in place with Velcro, you will not be able to move them or turn them. Ours are much shorter so I didn't have the issue you do, but I did make them flip-able top to bottom and side to side (takes planning with stripes). They are in tight enough to not fall forward when we travel. Chris put an extra strip of decorative wood in on the wall side to do that.
I would split the cushions in at least half, if I were doing your lengths. Actually, I'd probably go with option 3. The advantage of shorter cushions is they are easier to handle while sewing, and stuffing.
Have fun!
Kay
Old 01-19-2018, 08:54 AM   #3
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Solid color, no stripes.
Being sewn and stuffed by others. Do not see a need to move or turn.
Old 01-19-2018, 10:22 AM   #4
Mollysdad's Avatar
If the cushions are Ultra leather, or vinyl, or leather, allow a fabric side on the bottom so air can escape when you sit down. Any good cushion shop should be able to recommend covers.
Old 01-19-2018, 10:35 AM   #5
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Yep. Marine grade vinyl with vented back.
Old 01-21-2018, 05:42 PM   #6
1975 27' Overlander
Galena , Illinois
cushions
Are the cushions going to be used to cover the table to make into a bed?
Are there cabinet openings under the cushions?
75Bob is offline   Reply With Quote
Old 01-21-2018, 06:31 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
We made a U shaped dinette that makes into a big bed which is very functional. Our cushion design may not be what you have in mind. I thought I'd share a photo of the thing. It may prompt some ideas for you. It was done in a 69 Globetrotter.
David
Name:	1604 Dinette Done 1 (Small).jpg
ID:	302797   Click image for larger version
Name:	1604 Dinette Done Bed (Small).jpg
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Old 01-22-2018, 08:20 AM   #8
Cary , NC
I have made replacement cushions and think you should stick to same dimensions, and use lots of velcro! Spliting the cushions only will require lots of pushing back in place.
alreardon is offline   Reply With Quote
Cushions here, cushions there, cushions everywhere - 2007 Classic Gator113 2006 - 2010 Classic (all lengths) 13 07-12-2018 05:14 PM
Upholstering Cushions Northern California vs. Buying New Cushions pdozanne Upholstery, Blinds, Walls & Interior Finishes 1 03-21-2013 10:25 AM
Review - CCD Dinette Cushions by Accent Upholstery Stephen Mick Upholstery, Blinds, Walls & Interior Finishes 18 04-26-2010 07:55 PM
Dinette Cushions ? TexasStars General Motorhome Topics 2 01-21-2004 10:50 PM
Hinged cushions vs/ box cushions? Janet H Upholstery, Blinds, Walls & Interior Finishes 2 10-25-2003 04:00 PM
