Old 02-20-2020, 10:14 AM   #1
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Storage Ideas: When NOT Boondocking
Thinking outside the general mainstream thinking process, of experience, is for those who use AI. Artificial Intelligence: Simulation of human intelligence.
I prefer AOCI: Airstream Owner Common Intelligence.
Not wanting to disturb those who use only AI and not AOCI when solving problems. Experience from other Airstream and Some Other Brands of trailers is true AOCI. Experience trumps AI when the power is ON, or OFF the Grid.
One owner wondered about having a 'Trailer Port', aka Car Port to store their trailer, but their trailer had Solar Panels and no access to the electric grid. They did not want to run their batteries down with the Solar System covered under the 'CAR' Port.
You have to think Outside the Port and Box. AOCI, my friends has been very good on the AirForums! Geniuses dwell on this site every day.
(1)- Under a standard Car Port with roof, the easiest is to remove the batteries and have them in the garage, on wood blocks with a 12 volt battery charger. Yes... you have to remove the heavy batteries. Next time you replace the Interstate batteries, leave the nice plastic handles connected. They may have already died sitting at the Dealer's Lot and be useless. Use AOCI problem solving now.
(2)- Build a 'Trailer Port', rather than a Car Port. Automobiles no doubt have fewer Power Vampires draining their battery. Disconnect the batteries and leave them in the Battery Box, if you do not have Solar Panels on the roof. On later model Airstreams use a portable panel connected to the Battery Box, install Solar Panel(s) on the Car Port with Solar. Cost about $120 per 100watts at Costco. If you have Solar on the Airstream... go to point #3.
(3)- Build the Trailer Port for your TRAILER in MIND with the Solar Panels on the roof of your Airstream. Frame the Trailer Port as anyone would do with the Car Port. Now you have to consider WHY think Car when you want to protect your TRAILER and charge your batteries at the same time.
(4)- Trailer Port. Frame as you would the Car Port. Put a retractable CANVAS ROOF instead off corrugated aluminum or plastic. When weather is favorable, like the awning on our Airstreams, or another easier system, or not easy... open to expose to the Sun for Solar Power. When it is hot, raining, snowing depending where you live and what Latitude... close and protect your Airstream.
Before we had a RV Garage for our Airstream, Colorado's out door RV Storage year round was never a problem. Although many other climates NOT having a dry and no salt environment like the Rocky Mountains... any shelter is preferred. (Antique Car Buyers preferred WESTERN Junkyard Cars to humid, salty air junk cars to restore.)
Has anyone tried this before?
Your Airstream is an expensive asset and will retain its value by taking good care of it. Filiform can be minimized by having the slab poured concrete, rather on the dirt or gravel.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 02-20-2020, 11:50 PM   #2
2007 22' International CCD
Ray, just keep in mind that AI** will not be successful as long as NS*** abounds...
AI-Artificial Intelligence
NS-Natural Stupidity
And no, I’m not being cynical...
Old 02-22-2020, 07:09 PM   #3
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
during winter I store my 30 classic on jacks, tires covered and cover on trailer, batteries removed put in garage in a plastic container and checking sitting voltage every couple months.. when it get below 12.4 I put my trickle charger on it for a couple weeks till voltage go back up to 12.7 or so.
you can install a solar panel on top of the garage adn run wires down to cheap PWM charge controller to keep batteries up..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 02-22-2020, 07:29 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
1) Simply put skylights in the roof of the whatever you are going to call it.
2) As mentioned above, put about 200W of dirt cheap surplus residential panels on the outside of whatever you decide to call it.
Either way, your batteries should be fine.
Storage near Toronto - ideas, recommendations? andreasduess Winterizing, Storage, Carports & Covers 5 07-05-2013 01:23 PM
3rd Car Garage Ideas for Airstream Storage Jezibels Winterizing, Storage, Carports & Covers 30 11-17-2010 03:20 PM
New Storage Ideas! BIGED52 Airstream Lifestyle 0 06-10-2010 11:03 AM
Dinette area storage ideas Elvie 2005 and newer - Bambi all models 9 05-03-2007 11:21 AM
long term storage ideas in kansas or missouri? ashoc On The Road... 0 03-15-2006 07:07 PM
