10-14-2016, 07:34 PM
#101
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Originally Posted by J. Morgan
The fact of the matter is that the energy use of an Airstream, and even all trailers combined, is all but inconsequential to the bigger picture.
Whether a person powers with solar or a generator is pretty much moot.
Gradiens super tenui glacie.
We just spent a wonderful (Canadian) Thanksgiving up here on beautiful Vancouver Island nestled amongst the tall pine trees. Due to the coolness mainly from the sun not reaching through the trees, we used the batteries quite a lot and over the 3 days and I would have challenged anyone not to have used a generator and relied on solar alone.
That's the reality in the Pacific Northwest I'm afraid.
George
10-14-2016, 09:32 PM
#102
Spring
I'm sure my husband has probably had conversations with many of you concerning solar. We haven't completed our system yet, but Karl has decided to use portable modules, rather than roof-mounted, since they would give us some freedom to keep the aluminum cooking pot in the shade as much as possible.
Getting back to the original post, on environmental responsibility and justification, in my mind generators, solar or wind are not environmentally friendly. The weak link in the equation is those darn batteries. No matter what kind you use, they all have a relatively short life span. Yes, Lithium types weigh less, can hold more amp hours and live longer. But it's getting a bad rap in other applications right now and costs a lot more up front. Like Lead, Lithium is a "heavy" metal. Where do battery innards go after you turn the battery in for the core charge?
We don't look at solar as a way to justify what we want to do, AKA RVing. We have (2) 2000 watt inverter generators and the solar will be added as another energy source. If you like your electricity, can't have too many of those. Live thru any disaster (Hurricane Ike), even if your area isn't hit as hard, lack of electricity for a for a few weeks gets very old, especially in an all electric house. (No gas line here, can't install a whole house generator. Lot isn't large enough for a propane tank.) That experience has informed our decisions when making energy choices on our AS. Our new refrigerator doesn't run on gas. But when Hubby suggested an electric cooktop, I put my foot down. I not only wanted an oven, I also didn't want to be too dependent on electricity. By the way, I don't use a blow dryer. However, I occasionally use it on my long-haired rabbits to work off loose hair.
What would really impress me is if someone could come up with a way to provide electrical power without batteries or power lines/cords. Oh wait, Nicola Tesla was trying to do that. Westinghouse killed it, because he didn't see any way to make money off wireless electricity.
10-14-2016, 10:08 PM
#103
2006 25' Safari
St. Augustine
It depends. If you want power like you are hooked up when you aren't for AC etc, a Generator.
Solar is great but IMO it is "opportunistic power" with several caveats with mobile use. Naturally the idea is appealing but you really need direct sun or almost direct light to make the panels really work well, you need clear skies, you need a parking position that allows for no shade from trees, etc, etc, etc. Then you get free charging from your expensive system. I do not know what you think about expense but people are now buying batteries that cost $1100 each- LI 75amp/hr. because of solar. The advantage? It can be drained lower without harm and be charged more times with a five year warranty though I question its value compared to a good $104 deep cycle Johnson Control's lead acid 98 amp/hr with two year replacement. While it is true that the LI can utilize almost all of the 75 amps for use (around 80%), the 49-59 amps the wet cell offers for use isn't bad (50-60%). Granted the charge cycling is 400-500 wet cell verses 2000-5000 LI cycles is huge, so is the price. Batteries are a big part of solar. Still, there are those who want a mammoth solar system and will pay any price to have it.
I have both but my solar system is for boon docking and powering my meager basic needs with an expected 4.5 hour daily recharge using 350 watts of portable and tilting roof panels.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
10-15-2016, 06:12 AM
#104
Spring
No matter the energy sources one uses, RVing probably wouldn't be listed as an example of "practical" if one were to look up the word in a dictionary. It's one of those "do it because you love it" kind of things. We try to make up for the used resources by being good guests wherever we stay. "Leave it better than you found it" seems a good policy. Nothing steams my clams more than finding garbage in fire pits, and elsewhere, on a campsite.
10-15-2016, 08:42 AM
#105
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We are based in Arizona and tour the SouthWest. Lots of sun down here, so a solar system makes sense. We can carry a limited amount of propane and water.
To make the best use of what we have, in both trailers we converted to an instant on Truma Aqua-Go comfort water heater that is propane powered only and a Vitrifrigo refrigerator with a 12Vdc powered Danfoss freon compressor that needs 59 watts and does not run continuously due to better insulation than we had in the Airstream installed Dometic.
Depending on our destination, we carry one 2000 watt propane only powered Honda for the 23D since the Magnum hybrid MSH-3012 can augment starting the AC if desired. Towing with the Mercedes ML320 CDI we are weight and space constrained. There are five 100 watt AM solar panels on the roof and a 300 amp-hour lithium battery.
We can take the pair of propane powered 2000 watt Honda generators for the 31' Classic since we tow with a truck and the Magnum MS-2812 does not have the power augmentation feature. We have nine 100 watt AM solar panels on the roof and a 600 amp-hour lithium battery.
10-15-2016, 10:29 AM
#106
2015 28' Flying Cloud
Durango
Moot - adjective - open to discussion or debate, doubtful.
From that perspective, virtually any individual action may be considered inconsequential in the bigger picture. Environmental or cultural degradation is a cumulative result of actions by a society. The environment degrades quickly when individuals think that their actions, good or bad, do not matter.
I am as pragmatic as anyone, and have a realistic sense of where my actions fit into the bigger picture. Society is made up of individuals, however, and individual actions contribute to cumulative results.
Shifting to cleaner energy, at any scale, is important. If in doubt, visit China.
Reducing environmental impact (noise, emissions) within a campground is particularly worthwhile, as appreciation of the natural environment is the legitimate reason, IMHO, for going to such a place.
Safe travels,
Joe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
10-27-2016, 12:46 AM
#107
Pleasanton
I am not sure if you have ever watched the series "breaking bad". If you have, there is one episode where they and their RV are stranded in the AZ desert with a dead battery, the generator is out of gas, and they are low on water.
If they had even the most modest solar panel, correctly mounted or not, it could have been used to charge up the vehicle battery sufficiently to start the engine and allow them to drive back home.
IMHO, this by itself is sufficient reason to have at least a small amount of solar on your RV or trailer.
Even if you don't use the solar PV panels for power, they make a good shade.
10-27-2016, 12:55 AM
#108
Pleasanton
We don't look at solar as a way to justify what we want to do, AKA RVing. We have (2) 2000 watt inverter generators and the solar will be added as another energy source. If .
Hi, I will just comment to help ease your mind a little.
Lead is a heavy metal, Li is not.
Lead batteries have the highest recycle rate of any product on the market. It is so close to 100% that even the most environmentally responsible groups are impressed. They are very heavy, but a good quality, properly chosen lead based battery, along with the proper charging system, can last a long time.
There are a number of types of Li based batteries, IMHO, the proper ones for RV / camping use are LiFe based, and not some cheesy ones, but unfortunately only professional grade ones that cost $3000 / each for 140 A-hr. They are MUCH better and very safe, but expensive.
LiFe based batteries from professional grade suppliers can also be recycled, and frankly need to be if we want to keep using them. There is no reason that a good quality, professional quality LiFe battery with its own built -in BMS (battery management system) will not last 10 years in heavy use. Personally, I would not sell a Lithium based battery pack system that used an external BMS to anyone in the RV industry.
I hope that helps, not with the sticker shock, but with the environmental aspects.
10-27-2016, 06:41 AM
#109
Naples
Please clarify the last statement that you made in your post:" Personally, I would not sell a Lithium based battery pack system that used an external BMS to anyone in the RV industry."
Would you care to expand on the reasoning behind this position? It would seem that the majority of the lithium systems (LiFePO4) being installed into RVs now are of the 'external BMS' type, as there are very few companies that actually make an fully integrated drop-in lithium package.
What displeasure do you have with external BMS? I might agree that some companies that only make a BMS system as a universal application to a wide range of batteries might have some fitment and adjustment issues, but others like Victron, known world-wide for their complete systems integration techniques, use a proprietary BMS system.
All of their lithium sizes have communication cabling bonded to the batteries and emanating from the battery case. These cables are then daisy chained and fed to the BMS system to connect all of the internal sensors, which monitor temperatures, loads and charging to not only maintain the integrity of the lithium system, but will also cut the charge current if the ambient temperature drops into the 'NO ZONE' below 0ºC.
Further, what is your exact relationship to the lithium battery industry that leads you to your opinion? Do you sell or install lithium batteries? Do you have actual user experience with them?
I just can not accept blanket statements from folks with no direct experience or factual foundation for same to go unchallenged. Posting in this fashion is doing the members of this forum a disservice. We'll be looking forward to your response.
Thank you!
And BTW, $3000 for a 140 amp/hour lithium is a bit 'over the top'! Quality systems are presently available for significantly less, although are still expensive related to AGM systems.
lewster
10-27-2016, 10:02 AM
#110
2014 31' Classic
Apache Junction
Our 300 amp-hour AM Solar lithium (LiFePO4) battery sold for under $3,000 in 2015 and our 600 amp-hour AM Solar lithium (LiFePO4) battery was under $6,000 in 2015 as well. That price included the complete BMS system with disconnects.
These are real world numbers, not hypothetical.
10-27-2016, 11:37 AM
#111
Naples
Unfortunately, the cells used in your lithium systems are no longer available as SinoPloy is under contract to provide all of their production to the EV automotive industry.
Their lack of a consistent, reliable supply chain is one of the major reasons that AM Solar has partnered with Victron Energy for their present and future lithium needs.
Lew Farber
lewster
10-27-2016, 11:50 AM
#112
2019 27' International
2014 25' International
Boulder City
, Nevada
Ray's Tesla Coil experiences...
I feel I am actually receiving an education on Solar. Well done!
Starstream Post #102 What would really impress me is if someone could come up with a way to provide electrical power without batteries or power lines/cords. Oh wait, Nicola Tesla was trying to do that. Westinghouse killed it, because he didn't see any way to make money off wireless electricity.
I had a Tesla Coil. It stood about five feet high, maybe six feet, and looked like the Empire State Building. Back in the 20th Century, circa 1989.
I used it on Halloween to spook the kids out of their stopping for candy and treats. It buzzed and the top zapped into the air creating Ozone you could smell. The florescent bulbs hung from wires would glow... without any wires.
The neighborhood was attracted to this like moths to a bright light!
Radio reception was impossible as the electrical field obscured any possible reception. I did not ask neighbors if their TV or Radio reception was compromised.
I did not see how it affected television at the time. It sure was not good for AM Radio. If you touched anything metal, like a control, it would give you an electrical burn. Bulbs with no filament still would glow on the unit with DC power jumping the gap.
The original thought, as I understand it, was to put electricity into a home without any wiring needed. You turn on the Tesla and it would power everything without plugging into an outlet.
My Tesla was plugged into AC and then transformers and tubes must have to converted to DC and transmit within a radius... in my case, maybe six to seven feet radius.
I can not imagine one large enough to power a house. You probably would find yourself not wanting any metal objects, any where. Within an Airstream...?
The caustic Ozone near the coil would burn your eyes.
This was a great novelty for Halloween, but outside. I rather miss having it, but it was large, heavy and had tubes. At least I can say I had a Tesla Coil and happy to have AC in the house and DC in our trailer.
Human Bean
10-28-2016, 12:00 PM
#113
Pleasanton
Hi, I realize that you are a "go-to" person on this forum, and I respect that.
As far as your question, I only have 16 years of experience with Li based batteries and their use, so certainly there are people out there who have more. Regardless of the number of years, there are a lot of smart people in the world working on and with batteries of many types, many of them more intelligent than I am.
There are BMS systems which are "added on" to various size cells in order to build up a managed system. If you look at the wiring, many look like a spaghetti factory. This is acceptable for a stationary system, but for RV or marine use, vibration and moisture are important factors and I would not recommend to anyone that they be used.
This contrasts with a BMS which is intrinsically part of the battery package. Batteries like this are connected not only by the power cable, but also by pre-engineered intelligent networks that keep the system and individual cells inside properly managed. (an internal BMS) There is of course an external controller.
These types of systems are certified for marine and mobile use, and the wiring and cabling are designed for vibration and moisture.
Of course you already know this so I won't keep going.
10-28-2016, 12:22 PM
#114
Pleasanton
Originally Posted by eartick
I would like to know what you are using for a "combiner" for all these panels. Do you have a way to monitor efficiency of a bank or each to determine a bad cell.
Hi, just throwing out a helping hand to you.
There are two kinds of "cells" so I am not 100% sure which one you are asking about, cells that make up a battery bank, and solar cells that make up a solar panel.
Starting with the solar side:
There are monitoring systems that allow for looking at the output of each solar panel and identification if a particular panel is not putting out as much as other panels in the array. Typically, this is part of the electronics which optimize the panel output (such as an MPPT controller) to run the panels at the maximum power point.
If you look at solar panels on a home size array (say 3- 10 KW), this feature is pretty common, as there are a lot of panels and they are quite inconvenient to get to unless you have a good reason.
The most common monitoring systems for these arrays are based on data sent via the internet to a server, which dutifully monitors all of this to calculate how much you sell to the utility and how much you are buying.
There are also some versions which allow for collection and retention of the data locally and do not require an internet connection.
I am a big believer in respecting people's privacy, especially their individual location and time data. If a person chooses to share this information themselves, that is their decision, but if a solar panel (or battery ) monitoring system is broadcasting this information near real time, IMHO, it makes you vulnerable to theft.
Sorry for the long answer, but yes it is possible to monitor the individual solar panels and track the data yourself, or have it internet broadcast to a network server.
As far as going down to the individual solar cells inside of the panel, I have seen one panel offering that did this. The downside is that the monitoring takes up space and adds cost, so I didn't really look closely at it as something that was interesting for end users.
10-28-2016, 12:37 PM
#115
Pleasanton
Battery cells
It looks like you are building up your own battery bank, which is fine for a person with strong skills.
There are BMS systems on the market that provide ways to monitor the status of the individual cells, often this requires a computer plus software to do the monitoring, but it is out there.
I am sort of mixed about this feature set for people who are not highly skilled and very interested in the ultra details of the battery bank, even though I think the information is "interesting".
- Once you connect a computer to the battery bank, then the (skilled or unskilled end user) can change the settings in the BMS, and this can have non ideal consequences, even if they didn't mean to change the settings.
- If the computer is hooked to the internet, then it is impossible to completely protect against a computer virus, also potentially causing non ideal consequences.
- The time and location data being broad cast through the internet can be used for theft and other potential privacy interruptions.
It isn't that hard to connect all of this together and send the data to your smart phone. The question in my mind is - should you? Honestly, I am not so sure that it is a good idea.
My favorite approach instead is more like the "oil change" concept. Once every 12 months, either have a technician look at your system with an off-line monitoring software package, or take it to an authorized repair location.
Feel free to comment, I welcome your opinion on this area.
10-28-2016, 04:01 PM
#116
Goliad
That was it. Combining multiple cells and then monitoring their performance and through put. Found a simple little gadget that will get me what I want for $18.00. Measures current and voltage real time then over time keeps a running log of accumulated watts delivererd until you reset it.
Bought two of them and will install one on my solar and one on my battery outgoing.
And thanks for the response
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
10-28-2016, 04:09 PM
#117
Goliad
No problems. Worked on lead acid banks for years that were bigger than some houses.
Also understand networking and computer systems. Was an installer of midrange computer systems for process control platforms. These usually had three layers of firewalls if connected to the company net and it seems that in the last ten years all of them HAD to be.
The Frommes
Goliad, Texas
WBCCI #6256
10-29-2016, 07:00 AM
#118
2006 25' Safari
St. Augustine
Just revisited the thread and it is on "environmental mode" it seems. I have a different perspective on energy products. It seems that ANY energy use has an environmental price. I did not consider this until that Swedish study came out on the environmental impact of hybrid and battery operated cars. I was amazed. They impact the environment on the back, less while operating, worse when operating on engine, etc. Check it out on Tesla battery article or that study. Eye opening. One thing we can do is not be wasteful.
10-29-2016, 10:36 AM
#119
2021 25' International
Full timer
, Virginia
Well yes, but you're using batteries inside your coach no matter what - so if you're discussing "either side" of the thread, it's a zero point as both sides are equal in impact.
The only real differential between the two, environmentally wise, is the discussion of impact from generator construction/fossil fuel vs impact from solar panel construction. At what point does the solar option, construction impacts of acids, electricity, water, etc., tilt over and become a positive boon; rather than impact.
2024 Airstream Globetrotter 30RB
2022 Ford F350 Lariat Diesel
WBCCI 4CU 8118
10-29-2016, 07:41 PM
#120
2006 25' Safari
St. Augustine
It is true that batteries will be in the coach either way. I was considering two factors, efficiency and environment in my two posts. The differential between solar and generator from a novice perspective would assume that solar has no impact on the environment at all and engine emissions related to generators would be an obvious mark against them when that is not the case as you mention "tip the scale" per se.
