Old 01-10-2020, 10:27 AM   #1
Antiquepedaler
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Satellite TV
Has anyone with 200 watt solar system operated their satellite TV while boondocking? If so how much power is used in a couple of hours? Our tv is 12 volt but the inverter would be on to power the satellite.
Antique Pedaler
2021 Caravel 20 FB
Antique Pedaler is offline   Reply With Quote
Old 01-10-2020, 10:56 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
The answer will depend heavily on the efficiency of your inverter. Looking at the DirecTV receivers, the most power drain I see is around 20 watts. But it burns almost as much when it is off. I suspect your TV draws more than that, so it is probably that adding the satellite receiver will have a negligible effect on your total power budget. My H-24 is specified to draw around 12 watts, so at 12 volts that is one amp, but it will be more depending on the efficiency of your inverter. Even if the inverter is only 50% efficient, that would be 2 amps for 2 hours or only about 4 amp-hours per day. Your 200 watt array should be capable of delivering 50-60 amp hours on a good day.
Full disclosure - back of the envelope estimates, I have no direct experience with satellite on solar.
Al
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Satellite ALANSD Electrical - Systems, Generators, Batteries & Solar 9 08-19-2003 12:36 PM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 03:57 PM
Satellite from above 53flyingcloud Our Community 14 03-29-2003 09:46 AM
Satellite Question davthr Our Community 11 03-17-2003 11:31 AM
Satellite Equipment rdm Airstream Motorhome Forums 7 03-14-2003 10:00 AM
