Originally Posted by Mollysdad
If he wants a real 50 amp generator, his options are limited.
First, at all levels reject the open frame construction generators in favor of the "inverter generator".
You said "AZ" but also "winter" so I think he should limit his thinking to 30 amps.
There's lots of fine generators out there, Champion 4500, or the top of the line Honda EU3000is.
In the real world you get tired of bringing gas daily, and no generators will hold a large supply. You can jury rig a 6 gal marine tank to feed a small generator.
I'll bet he favors windows open over a/c for most days.
You are correct, in order to provide a full 50AMP service (approximately) using generators, dual EU7000i are required, at $5K apiece. Not to mention over 1 gallon per hour per unit to run. The dual EU2200 provide just over 30AMP, at $1.3K each.
