Old 12-02-2023, 10:04 AM   #1
2023 25' Globetrotter
Ancient City , Florida
Parasitic stand by loads
Planning a couple week long boondocking trips in our 25fb (electric fridge)
Plan on upgrading batteries before trip. Currently have 300w rooftop and will add 200 portable.
Are their parasitic standby loads to look out for? TV, Stereo, WH that I should pay attention to, throw breakers etc?
Will probably change charger and maybe converter at same time as the current fan drives me nuts at night.
Inverter use would be extremely limited.
Thanks in advance
G8trwood is offline   Reply With Quote
Old 12-02-2023, 10:27 AM   #2
r3z
Los Angeles , California
I keep fantastic fan on 0 even though it is off as I understand the rain sensor (and red light ) still consume battery even when off.
Other than that make sure there are no storage lights on by accident
r3z is offline   Reply With Quote
Old 12-02-2023, 10:42 AM   #3
2007 16' International CCD
Somewhere , Colorado
Propane detector is hot wired and always on; in my trailer it draws about 3Ah per day. Other things to watch for are the radio memory (remove faceplate took care of it in my case), and power to tv antenna which can be switched off.
If battery upgrade is to lithium, make certain that the converter and solar are set to lithium, and get a shunt based battery monitor (like Victron 712) or you will have no real idea of the state of charge of the batteries.
If you track the SOC, deploy the portable panels as needed, and get decent solar conditions you should be ok.
field & stream is offline   Reply With Quote
Old 12-02-2023, 11:12 AM   #4
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Your heater blower and electric / compressor fridge may be the most battery demand. If you keep fridge closed hour or two before sundown. Possibly throw some helping gel frozen packs in fridge it may not need to cycle as much overnight.
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2020 GMC Sierra Denali Diesel 2500 4X4 10 spd 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 12-02-2023, 11:18 AM   #5
JeffKim's Avatar
2021 16' Bambi
Forest Lake , Minnesota
We have the same year and model. In addition to the 300W on the roof, I added 4x100Ah lithium batteries, a Victron shunt, and have 2x200W external panels (700W total). With that we can go about a week unplugged in the summer with decent solar running judiciously: computers, cellular router, and Starlink (80W/hr total). We also adjust the refrigerator down (up?) so it keeps things barely frozen.
So, I'm not sure if going to 2x100Ah lithium with 500W solar will get you a week (if anybody's asking). If you don't have the other devices like us, perhaps. Overstating the obvious, after installing upgrades, including installing the shunt (mandatory with lithium IMHO) I'd try see how long power lasts in the driveway unplugged (or get some idea of normal usage).
I believe your converter will also have the infamous WFCO AD charger which is supposed to auto-detect lithium but is unreliable. Besides the fan noise, it's probably not a bad idea to replace the charger. The Progressive Dynamics charger has a good reputation but I went with a Victron Phoenix, more expensive but optimizes charging in conjunction with our other Victron equipment.
As far as other parasitic loads, the powered TV antenna is one that sometimes gets overlooked. I don't think it uses much but over time it doesn't hurt to turn it off if not using the TV.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 12-03-2023, 10:31 AM   #6
Charleston , South Carolina
Go to 600ah of lithium and 600 watts of solar.
Or, take a Honda 1000 for charging.
Look at Goal Zero Yeti Pro 4000.
I would not attempt to boondock without more capacity. If you want to enjoy the quiet, then get a Yeti and several panels.
Instagram @coasttocoastphotoatl
coasttocoast is offline   Reply With Quote
Old 12-03-2023, 10:31 AM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The typical inverter acts as a parasitic load. Folks have reported some pretty major current going into them.
The best approach is to put in a full disconnect switch. That way you don't have to wonder if all the loads are shut down.
Old 12-03-2023, 02:16 PM   #8
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Several people have mentioned propane detectors, etc. that are safety devices. Of course, it behooves you to leave these operational when boondocking. uncle_bob mentioned the manual on/off switch - that's useful when the RV is stored and you want to ensure no battery power is drained by parasitic loads.
Be sure you know how to turn off your inverter when it's not in use. Our inverter, just having it turned on, drains nearly 2 amps and that's continuous - regardless of whether I'm actually using an inverter receptacle.
Upgrading the charger/converter/inverter is a good idea. At a minimum, be sure you have a precision shunt in the system and a readout so you can monitor the power draw. It's easy to leave a few lights on here or there, use a fan, etc. and not realize how much power you're consuming. The precision shunt and readout will aid in monitoring the state of charge (SOC) and other parameters related to your electrical system. There are lots of threads on the topic.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-04-2023, 12:13 AM   #9
27ftToaster's Avatar
2021 27' Flying Cloud
Wake Forest , North Carolina
Don't forget about the sub woofer. Another parasitic draw.
2021 27' Flying Cloud FBQ, Rear Hatch, 380w Solar, 400ah Lion Energy Lithium,
3000w Multiplus II, Dual Orion 30a DC-DC Chargers (60a total), 3" Lift kit, Maxxair Fan
2020 RAM 2500 6.7L Cummins Diesel
27ftToaster is offline   Reply With Quote
Old 12-04-2023, 06:56 AM   #10
Lots of good info. Thank you
Old 12-04-2023, 07:46 AM   #11
Half a Rivet Short
2022 Interstate 24X
Hi
Just to be clear: even when the inverter is turned off, it still may be pulling 1/4A or so. It's hard wired direct to the batteries. There is no way to eliminate this load without a full disconnect (either a switch or pulling the cable). The propane detector that everybody is bothered by likely pulls 1/10th the current that the inverter does when it is shut off.
Old 12-05-2023, 03:01 PM   #12
JeffKim's Avatar
2021 16' Bambi
Hi
This had me wondering, so I contacted the Progressive Dynamics tech guy who was trying to diagnose my remote problem*. This is what he tells me for our 1000W PD 1610:
On: He said it draws 1.68A with no loads.
Off:
There is a current draw to be able to turn on the display and the processors . That is in the range of 17-20mA. If there is a remote attached that will add another 12 mA.
So, maybe 32mA at the top end. In a week that would consume 168hr *.032A = 5.38Ah, so not very much.
*YAWI (Yet Another Warranty Item)
2017 Audi Q7 3.0T
WBCCI 6343
Old 12-16-2023, 04:04 PM   #13
Mesa , Arizona
Most of the safety features (carbon monoxide, LP sensor, and tire sensors for example), will bypass the DC disconnect switch.
In the Airstream this is the "use/store" switch which is often by the front door.
If you are trying to eliminate DC parasite loads, I would recommend the following:
-Put Airstream in "store" mode on the DC disconnect switch
-Remove all Positive loads from the battery
-Place all 12V positive leads on a junction post
-Produce a cable from said junction post to a Blue Sea Mini On/OFF switch
-Produce a cable from Mini ON/OFF to the battery-positive terminal
Boom, no more parasites.
This is a must if you transition to lithium in the future, which you should!
Superstition Solar
Tempe, AZ
SuperSolarAZ is offline   Reply With Quote
Parasitic Current Drain? JDKub Batteries, Univolts, Converters & Inverters 3 10-24-2020 09:47 AM
Parasitic Current Numbers uncle_bob Electrical - Systems, Generators, Batteries & Solar 23 06-21-2018 08:17 AM
Parasitic draws and 12V system M and M Boondocking 20 12-13-2015 09:31 PM
Parasitic electrical flow waltc 2009-2015 Flying Cloud 20 09-17-2014 06:44 AM
Parasitic Drain aftermath Batteries, Univolts, Converters & Inverters 9 03-15-2010 10:23 AM
