Old 06-17-2017, 11:04 AM   #1
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
New 2018 models out on AS site
2018 models are out and described. Can't believe it but AS is using pass through. On inverter and upgraded to a multi-stage charger.....
And added a battery disconnect.
Troutboy
Troutboy is offline   Reply With Quote
Old 06-17-2017, 12:04 PM   #2
Lynnwood , Washington
Total noob here...
Okay, so they are saying "improved battery disconnect feature, multi stage converter, combined inverter outets, and dedicated HDMI plugs".
So can anyone elaborate on what this means? Also, in your opinions, would any of the new upgrades make it worth purchasing a 2018, or should I try and score one of the remaining 2017's at model year end discount pricing?
NWbarber is offline   Reply With Quote
Old 06-17-2017, 12:17 PM   #3
Troutboy's Avatar
Parker , Colorado
For me. I replaced all the electronics anyway with what I wanted. So I would go for 2017 cheaper and rip out the stock electronics.
Troutboy
Old 06-17-2017, 12:26 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Yup my 2017 will get a Victron Hybrid inverter, Lithium, 600+ watts of solar, proper battery disconnects, system monitoring, etc... the 2018's have another price increase which wasn't worth it given that I am going to re-configure the energy system anyway...
Check out the improvements on the classic... looks like they made a lot of changes with the AC / heating system control unit. Makes me think that the first attempt in this area was problematic....
wulfraat is offline   Reply With Quote
Old 06-17-2017, 01:32 PM   #5
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Look closely for the water filter...
Old 06-17-2017, 01:47 PM   #6
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Please excuse my ignorance but what is "pass through"?
Old 06-17-2017, 01:51 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
On the 2017 Classic, you have multiple control gizmos. You have the control panel that does almost anything from many places. You then have the Aldi panel that does the hot water heat. Next up you have the thermostat that runs the AC/ Heat pumps. I'm not really sure if moving all that into one big color panel is a step forward to less confusion or a move to ever deeper menus to navigate. I'd bet it *does* let you adjust things like the AC from more locations. Until somebody crawls around one with a camera and does some poking, it's all a bit unclear.
Old 06-17-2017, 01:53 PM   #8
Half a Rivet Short
Hi
I believe it's a reference to a transfer switch. It was previously available on part of the lineup, but not on all models. It switches the "inverter" outlets to shore power. No more moving things between outlets.
Old 06-17-2017, 02:02 PM   #9
Hans627's Avatar
Hi
OK, got it and thanks!
Old 06-17-2017, 02:08 PM   #10
wulfraat's Avatar
A pass through inverter powers one or more 120v circuits in the trailer. The front side of the inverter is connected to the breaker panel which provides power to whatever is on the circuit (TV, DVD, etc..). The backside of the inverter is connected to 120v shore power and 12v battery power on 2 separate lines obviously.
When 120v shore power is present the inverter "passes through" that 120v supply to the breaker panel. When 120v is not present then the inverter automatically switches to battery supply, inverts 12v to 120v and supplies the same breaker panel.
This allows you to have a single outlet that is powered by shore power when available, otherwise will automatically fail over to inverted battery power.
No need to plug the TV/DVD into a different outlet for inverter-supplied 120v power.
PS - a transfer switch has a similar outcome, however is wired differently and requires separate hardware from the inverter.
Old 06-17-2017, 02:17 PM   #11
Hans627's Avatar
Totally understand now! Thanks for taking the time to explain it in more detail!
Old 06-18-2017, 07:50 AM   #12
Half a Rivet Short
Hi
So an inverter that is advertised as "integrated transfer switch" is different than and inverter that is advertised as "pass thru feature" ?
Old 06-18-2017, 08:57 PM   #13
wulfraat's Avatar
I'm not sure if they are the same. That is a question for Lewster.
Generally speaking a transfer switch has a time delay before switching sources.
My GoPower transfer switch takes about 5 seconds to activate / switch sources.
A true "hybrid" inverter which also happens to have pass thru capability is instantaneous switch over (milliseconds).
I'm not sure if there are "pass thru" inverters that are not hybrid (ability to supplement shore power with battery power)
Old 06-18-2017, 09:01 PM   #14
wulfraat's Avatar
My GoPower transfer switch takes about 5 seconds to activate / switch sources when 120volts shore power goes dark.
A true "hybrid" inverter (ability to supplement shore power 120volt current with inverted battery current) with pass thru capability is instantaneous switch over (milliseconds).
I'm not sure if there are pass thru inverters that are not hybrid but yet provide uninterrupted cut over.
When to order a new Classic 30 (2017 or 2018) cetanorak 2016 - Current Classic (all lengths) 10 06-19-2017 07:56 PM
2018 models theBSLodge2 Our Community 1 05-14-2017 08:42 PM
New colors for 2018 hostage46 2009-2015 Flying Cloud 6 04-08-2017 09:52 AM
2018 New AS's...taking orders now? gypsydad Our Community 1 03-18-2017 11:12 AM
2009 Airstreams - Web Site for Models PeeWee Off Topic Forum 0 10-01-2008 10:33 PM
