Old 03-11-2020, 11:22 AM   #1
2019 30' Classic
Belleville , Illinois
Hutch Mountain Honda Eu 2200i & easy start
Can anyone advise if I will be able to run air conditioner (15k) if I add a Hutch Mountain propane conversion kit to my Honda EU 2200i?
I works using gasoline but I understand propane may be less efficient.
Thanks.
Presitla99 is offline   Reply With Quote
Old 03-11-2020, 12:07 PM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I've got the 2200i and Hutch Mountain conversion and it works just fine with easystart.
Buy the stand for the large regulator if you plan to sit on the ground. The regulator has to be upright! The arrow on back points up. After pulling my back out trying to start the generator, Hutch said: "Is the regulator pointing up?"
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 03-11-2020, 12:20 PM   #3
Tyrinius's Avatar
2009 30' SO Classic
Alexander City , Alabama
Yes, you can. Be advised this ability will be slightly diminished at higher altitudes.
~ 2009 30' Classic SO ~
~ 2018 Ford F-250 Lariat 4x4 6.7L Turbo Diesel, Diamondback HD Truck Cover ~
Victron 3000W MultiPlus, BMV 712, 100/50 SmartSolar, 600W Renogy, BattleBorn Lithium
MicroAir Soft starters, SeeLevel Tank monitor, Maxim Skylights
~ Slide Out Society #089 ~
Tyrinius is offline   Reply With Quote
Honda EU2200, Propane, Gas, Easy Start load testing ghaynes755 Generators & Solar Power 6 09-05-2019 08:33 AM
Easy start; use of Honda eu2000i with 50 amp classic Menno Generators & Solar Power 9 08-06-2019 04:50 AM
Honda 2200i 30amp PROPANE w/Easystart! stewartprice Airstream Classifieds 0 06-22-2019 04:27 PM
Hutch Mountain Tri-Fuel Option chili4u2 Generators & Solar Power 1 07-14-2017 05:39 PM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
