Old 03-04-2017, 12:41 PM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Generator in back of TV
I have a Yamaha 3000 generator I'm considering taking to dry camp. Is it acceptable to run it in back of truck? Reason is it's pretty heavy to load and download.
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 03-04-2017, 12:52 PM   #2
Mollysdad's Avatar
I don't see why not as long as it's not enclosed.
I plan to do exactly that.
Old 03-04-2017, 01:02 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
That is also what we are planning, using a 12' propane hose between the generator and the low pressure propane outlet on the front of the AS.
SeaLevel is offline   Reply With Quote
Old 03-04-2017, 01:06 PM   #4
1976 31' Sovereign
Oswego , Illinois
Why not I do all the time or some times I have 12 volt winch set up fastened to cross bed tool box with ramp then winch into or out of pu. if staying for a time and want to use pu for hauling, most time just leave in truck
Old 03-04-2017, 03:19 PM   #5
Journeyman
2016 25' International
Deerfield , Massachusetts
I think the folks from Long Long Honeymoon do that as a matter of course. Uncovered for ventilation...
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 03-04-2017, 04:19 PM   #6
Florence , Alabama
Thanks, if my older 3000 will work it'll save me from getting a pair of the Y2000s, although it's tempting.
Old 03-04-2017, 04:29 PM   #7
1976 31' Sovereign
Oswego , Illinois
Smile
Uncovered for ventilation or if covered bed, tailgate open is mandatory, preferably open bed so not trap sound. Be a good neighbor unless off in boonies by yourself.
Old 03-04-2017, 04:34 PM   #8
1976 31' Sovereign
Oswego , Illinois
Smile
If older works why spend to keep up with others, unless unlimited funds. I have 5 gen. of various sizes as each has a purpose plus none are new models, they work just fine.
Old 03-04-2017, 05:32 PM   #9
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Generator in truck
We also started leaving the gen in truck and for multiple reasons prefer it.
Quieter, less lifting, more secure, right near the propane tanks and minimal fumes Have the newer Champion 2800 duel fuel inverter with electric start...no cord pulling). Fits just under the closed touneau but keep rear section open for venting. Perfect !
Vantair is offline   Reply With Quote
Old 03-04-2017, 05:45 PM   #10
PKI
PKI's Avatar
Walnut Creek , California
Safety instructions are supposed to say "place 15 ft from any operational air vent or window". Truck bed might be a bit short on that specification for you by the numbers tow folks.
Kind of wondered why there was not an exhaust hose option for RV generators, if distance was a real important parameter. Pat
Old 03-04-2017, 07:12 PM   #11
Vantair
Vantair's Avatar
Agree. So we position a large metal bowl reflector near gen exhaust to cup and route all "up and out". However, propane burns noticeably cleaner with far less carbon fumes / contaminates. Of course carbon monoxide is always on mind so 2 sensors in rig for that.
Old 03-04-2017, 10:34 PM   #12
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I have the same setup.. I made my 110v cord and propane hose to custom fit in length. They go out over the tailgate (left open) and down to the trailer tongue coupling safety pin bail. The propane quick connects to a shut-off, then under the tank and up to a "T port" 3 way valve. This way you can draw off of both bottles at the same time in real cold weather. The AC cord goes to a receptacle on the front of the trailer just roadside of the tank cover. You can leave it connected when under way. Works great.
guskmg
Old 03-05-2017, 05:52 AM   #13
2014 27' FB International
Macon , Georgia
I wanted to buy a 3000 Yamaha or Honda and neither will fit under my tonneau cover. Looking at Champion 3500 Dual Fuel now. It will fit.
Roadtech is offline   Reply With Quote
Old 03-05-2017, 06:22 AM   #14
FCStreamer's Avatar
2014 30' Flying Cloud
Let us know if you get it and what you think about it.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 03-05-2017, 11:36 AM   #15
Vantair
Vantair's Avatar
Generator Running in back of TV-propane
Here's a sample of the Champion 2800 duel fuel operating with quick connect propane connections to hidden regulator in front propane cover.
Tailgate closed with rear touneau section open for venting. Much reduced generator sounds are then pushed "upward" and not radiating 360 out in open. Use a 14" metal bowl to channel / route fumes, heat and sounds up and out. Propane much cleaner fumes wise and cooler.
Everything stays comfy cool, quiet, safe and visibly hidden. Can't even tell a gen is running from 30ft out and nothing from next site over. Did many a sound test with this scenario and Love it !
Old 03-05-2017, 12:06 PM   #16
Mollysdad's Avatar
I've been looking into that. What tow vehicle do you have? Someone reported the Honda 3000 was 20.5 inches, and the Tundra I measured was 22". Leer makes a tonneau that has a small hump in the styling. It seems that would add height inside. The 700 series. (I'll bet ARE does too.)
Old 03-05-2017, 12:14 PM   #17
FCStreamer's Avatar
The specs say the Honda 3000 is 22" high.
Old 03-05-2017, 12:42 PM   #18
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
How much propane does it take to run, say, a 2000W generator? Does it draw it down quickly?
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 03-05-2017, 01:50 PM   #19
Florence , Alabama
If I use the champ 3400, can I not just hook it up to the forward Lp outlet that is for the grill, or do I need to look into tees, reg and such?
Old 03-05-2017, 02:06 PM   #20
Mollysdad's Avatar
Every site reports something different. I don't know it that includes the box as in "shipping size" I'll have to measure one at camping world or somewhere selling them.
The 20.5" was from someone on this site.
Some take the rubber feet off, but my experience says not to, it's part of their noise and vibration dampening.
The Tundra I measured was to the top of the bed, so a tonneau would be higher.
2017 AI back huge back TV obstructs walkway Perpich Audio, Video & TV 0 10-07-2016 11:48 AM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Generator in back of Pickup truck Rawn77 Generators & Solar Power 20 07-22-2010 06:20 AM
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 05:24 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
