Old 06-26-2020, 02:35 PM   #1
SailAS's Avatar
2007 25' Safari FB SE
Sugar Land , Texas
Front Generator Mount
What are your thoughts on this front hitch mount I built for my Gen set? It sticks out 24 inches from the front bumper and is at hitch height of 14 inches. Easy to lock up to the front tow points on truck & My power & propane hoses allow me to run it while still hooked to trailer.
ID:	371246   Click image for larger version
SailAS is offline   Reply With Quote
Old 06-26-2020, 05:23 PM   #2
Mollysdad's Avatar
I think it's pretty cool!
However, you can't see it, so I'd worry about parking and crashing into a signpost or car.
Also, it blocks your front license plate, is that a big deal in TX?
Old 06-26-2020, 06:14 PM   #3
SailAS's Avatar
Sugar Land , Texas
It doesn't really block much in the way of airflow as its below most of the radiator area. Yes it is "out of sight" but I could always add a "flag staff" to mark it. As to the License plate, I'm not sure. The mount does have a "second" rcvr so I could make the plate "plug in" as well.
All good comments and things I did consider. There is space between the "back" (actually the front with controls) of the generator and grill for access to all gen set controls which allow for air flow as well.
Thanks.
Old 06-26-2020, 07:21 PM   #4
2010 27' FB Classic
N/A , Texas
Just wondering, have you tried driving with that set up in the rain, and if the nylon cover is enough?
I like your idea using a front mount. How long are the ramps? Did you make the ramps or did you purchase those?
"Thereís two kinds of people, them goiní somewhere and them goiní nowhere. Andís that whatís true". -Ben Rumson
Old 06-27-2020, 09:39 AM   #5
SailAS's Avatar
Sugar Land , Texas
I have not had a chance to drive much yet but I am concerned that the cover may not stay put. It is just Nylon so I msu make a better cover out of Sail material (dacron).
The ramps are 6 feet znd from Harbor Freight. I have less than $50 in the whole thing since I already had the front hitch. You can buy these for sbout $150 to $200...
Dwight & Ellen + (the Beagles)
2011 F350 SRW King Ranch, 6.7L, 3.55 ELD, Billsteins, Hellwig w/ Reese Dual Cam & 800# bars. 2007 Safari 25 FB SE (stock - well sort of)
Old 06-27-2020, 10:37 AM   #6
2010 27' FB Classic
N/A , Texas
Thanks SailAS!
And I have a last question. Are you able to push the Yamaha 3000 up the ramps by yourself or is a helper required? I know that is a heavy generator. Maybe your 6' length on the ramps puts the incline at a low enough rise to make it doable for one person.
Also may I suggest a couple of simple drop thru pins to fasten the ramps to the carrier when loading. I would be afraid of them slipping off the carrier with a load on and breaking a few toes. Just a thought. You really got me thinking on this project of yours. I may do something similar if running my gen from the back of my pickup bed doesn't work out for me.
Old 06-28-2020, 10:28 AM   #7
SailAS's Avatar
Sugar Land , Texas
I can easily push/pull the gen set up the ramps by myself & I'm 71 years old.
Old 06-29-2020, 08:43 AM   #8
2010 27' FB Classic
N/A , Texas
You've been a great help, thank you.
Old 07-04-2020, 04:57 PM   #9
1985 31' Sovereign
Lovettsville , Virginia
Nice work! I have been contemplating a similar setup, thinking it would be a lot easier than pushing the generator up into and out of the truck bed (not happening when hitched up to the trailer.) It reminds me of the set up my step father used for his fishing cart.
85 Sovereign is offline   Reply With Quote
Old 07-05-2020, 01:20 AM   #10
2016 30' International
redondo beach , California
Don't you think that if a strap breaks or fails that it would cause a serious accident?
More redundant straps for safety.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 07-06-2020, 06:26 AM   #11
SailAS's Avatar
Sugar Land , Texas
"Hold Down" straps do come with different ratings depending upon how much you spend. I regularly haul $25,000 motorcycles in my truck and almost always when we're towing the AS.
That's the primary reason I wanted the bed of the truck as free of obstacles as possible. The bikes weigh up to 765 lbs. I don't use cheap tie down straps.
The ones shown in my pictures are rated at 1000 libs working strength & 3000 lbs breaking. Thats a safety factor of circa 15 to 1. I'm more worried about the handles on the gen set breaking than those straps.
You can use more if it floats your boat.
BatteryMinder - to mount or not mount, that is the question. Ruffn It Generators & Solar Power 4 12-11-2017 02:51 AM
2017 Flying Cloud 30 ' Hub Mount / Stud Mount question twolanehwy General Repair Forum 3 09-24-2017 02:03 PM
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 04:31 PM
mount generator on a frame? bronywolfe Generators & Solar Power 2 05-30-2008 04:54 PM
Flush Mount or Surface Mount Zac&Kristin Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
