There's quite a bit to unpack in your post and questions.
I can chime in with a few answers, but not all. You connect the generators to the Airstream using your standard power cable. I think the Honda companion has a 30A RV connector, so you'd use a dogbone to connect your 50A Airstream power cable.
Gasoline vs. propane is a personal decision. Many prefer propane because it's simple, it doesn't require you to carry gasoline cans, etc. That said, if you camp at higher altitudes you'll find that propane doesn't provide as much energy/power as gasoline, which becomes more important at higher altitude where you lose about 3 - 4% of your power per 1,000 feet of elevation. Additionally, it's easier to refill a gasoline can than a propane tank. Personally, I use gasoline and I'm happy with it. You may find propane more attractive.
I use a RotoPAX gasoline can in my truck bed to transport fuel. it works beautifully. If you choose to use propane, then you can use a propane tank, or you can convert your generator(s) to run directly from the low pressure propane port on your Airstream. I choose to prioritize propane for running my furnace, stove, fridge, water heater, etc.
Solar and lithium is a deep rabbit hole, and also a personal choice. It's expensive, but it's very cool. I have solar and AGM batteries and these work very well for me most of the time, but for longer trips or trips where I need air conditioning, the generator is necessary.
Good luck with your new adventure!
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
