Old 07-05-2020, 09:01 AM   #1
2020 22' Bambi
Seacrest , Florida
Crushed boondocking dreams. Need Generator Help- newbie
Hi all,
From reading this forum I learned that I needed to install an EZ Start to run the AC off my generator on our 2020 Bambi FB. That was installed.
I have a Honda 2000i generator (see pic) with two 120v outlets. I’m using a dog bone 15 AMP to 30 AMP to connect the AS to the generator.
When I try to turn on the AC nothing happens. The first time I tried it did come on but I had a circuit overload. While connected to shore power I started the AC multiple times in case the dealer did not give the EZ start time to “learn”. But that didn’t help.
The shore power cable does not light up (red light) when plugged in to the generator but it does light up when I plug it into a regular house outlet using the same dog bone.
I’ve been told I may need to get power from both outlets out of the generator to make this work. But those adapters don’t seem available? Is that even the issue?
Not sure what I am missing...Both the AC and the generator work independently. Hoping you all can help. Thanks!Click image for larger version
Erika_C is offline   Reply With Quote
Old 07-05-2020, 09:39 AM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
It doesn't make sense that the red light in the Airstream doesn't turn on when you plug into the generator without the A/C on. Are you sure you are getting power through your cord? You may need to press the reset button on the generator. Once you get power from the generator to the Airstream . . .
Try turning off your controller (battery charger) before starting the air conditioner. The controller is on one of the circuits controller by a circuit breaker. The battery charger is probably causing the overload when you run your air conditioner. Also make sure the refrigerator is set to propane or DC. A 2000W generator is just big enough to start the air conditioner. You have to be sure to turn off any other 120V draws before turning on the air conditioner. Once the air conditioner starts, you may be able to turn the refrigerator back to 120V and the air conditioner will continue to run. But when the air conditioner cycles, it might overload the generator again at startup with the refrigerator on 120V.
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
Old 07-05-2020, 10:45 AM   #3
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
By any chance, are you using a surge guard or some other type of voltage protection device when you connect to your RV? If so, you may need to "fix" the floating neutral before electrons can flow to your Airstream.
2019 Flying Cloud 30FB Bunkhouse
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 07-05-2020, 10:49 AM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Quoting:
I did exactly that with an older EU2000i. It works with no problems, even on propane.
If the person who installed your EasyStart didn't train it right, it is not as simple as doing three more starts. Something has to be done to the EasyStart to put it back in learn mode. If this is the problem someone will have to go p on the roof.
Did you check the breaker and GFCI on your generator? I am not familiar with the generator you posted a picture of but it says it has a built-in GFCI. Others have reported problems with something in the trailer tripping home GFCIs. That may be your problem. I have run my trailer from a GFCI-protected outlet without problems but that apparently is not the general case.
You should not need to come out of both outlets. The generator output is 13A and the outlets are rated for 15. I run my trailer from a single outlet on my Honda.
Make sure your fridge is on propane only, not automatic. If your water heater has an electric option, turn that off and use propane only. Particularly if your batteries are discharged, turn off the breaker to the converter, or preferrably run the trailer without air conditioning until the batteries are charged and then turn on the air conditioner. At this point you should b able to leave the converter breaker on.
I think your generator is not putting out power after the original overload. Reset the breaker and GFCI as required and try again.
Al
Old 07-06-2020, 06:14 AM   #5
AirMiles's Avatar
Its your lucky day! LOLOHO just answered your question with a video about running air conditioning from a generator:
(O+5200)
Old 07-06-2020, 09:39 AM   #6
2017 25' International
Framingham , Massachusetts
Search about making your own neutral to ground plug. You need to make one of these to get the Honda generator to power your Airstream. This is why the light won’t light up on the cord. It doesn’t detect the proper ground circuit.
quietguy is offline   Reply With Quote
Old 07-06-2020, 10:54 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Sounds to me like you now have a bad connection in your 15 to 30 amp dogbone or in the generator outlet. Check to see if the red light comes on on shore power if you can do that. Switch the dogbone to the other outlet on the generator.
If the trailer works on shore power and the generator powers other stuff that is plugged into the outlet then it sounds like the dogbone is gone.
Yes, in general you would want to switch off everything you can to start the AC on generator. But...the generator makes about the same output as a 15 amp short connection so if it works on one it should work on the other.
Maybe the inlet breaker on the trailer is tripped if you cannot actually check it on shore power now that would be a good place to start.
Old 07-06-2020, 01:16 PM   #8
2020 22' Bambi
Seacrest , Florida
I know. I think this is the main problem. It is not bringing any power. So I can't even get to the point of turning off the converter and/or refrigerator. By the way my AC does not run off propane. So it can't be switched to that.
Old 07-06-2020, 01:19 PM   #9
2020 22' Bambi
Seacrest , Florida
Thanks for the tip. The dogbone worked with a regular extension cord to power up the airstream from my friend's house outlet...
I am pretty sure I tried both outlets on the generator but will try again (generator was just serviced but I will try to plug other items in to check. I also have a GFCI plug tester). I will be on shore power tonight so I can check to see if the circuit has been tripped before I try again.
Old 07-06-2020, 01:20 PM   #10
2020 22' Bambi
Seacrest , Florida
I did buy a ground plug. I will try using this on one of the outlets to see if it works. Thanks for your help!
Old 07-06-2020, 01:21 PM   #11
2020 22' Bambi
Seacrest , Florida
Not sure what fixing the floating neutral means. But I am not using a surge guard on this set-up. I will try to put a ground plug on the other outlet to see if that works. I do have one of those.
Old 07-06-2020, 01:25 PM   #12
2020 22' Bambi
Seacrest , Florida
Meant to say my refrigerator does not run off propane. Only two way electric AC/DC.
Old 07-06-2020, 01:48 PM   #13
AirMiles's Avatar
Then switch it to DC while trying the Air Conditioner. Once you get the Air Conditioner running, switch the refrigerator back to AC. If your generator is overloading, you want to turn off everything that is using 120V AC power and then turn on the generator. Your generator should be able to run the Air Conditioning.
(O+5200)
Old 07-06-2020, 02:42 PM   #14
1988 25' Excella
1987 32' Excella
For a short test just turn the fridge off. Then back on when the AC is running. I doubt that is your problem but it could be, I guess. Also be sure the electric hot water heater is not on.
Old 07-06-2020, 02:53 PM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Eirka,
Mike Sokol can explain this neutral grounding plug feature better than most.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-06-2020, 04:23 PM   #16
Lawrence , Kansas
A number of you have mentioned the "dog bone". Being brand new to the Bambi world, I know I need a "dog bone", but don't know if I need a dog bone 15 AMP to 30 AMP or 30 amp to 50 amp, and I also don't know which end should be male and which end female. I so appreciate any input you can provide for me!!! Am sooo looking forward to getting our new Bambi next month!
SUP'n Woman is offline   Reply With Quote
Old 07-06-2020, 04:56 PM   #17
2020 20' Bambi
Clayton , North Carolina
On the 2020 Bambi refridge. DC/AC only as mentioned by OP. If you have battery disconnect switch on and inside dial of fridge on and no shore/generator then it runs on DC, obviously. If you turn off battery disconnect switch while inside of fridge is turned on and plug in shore/generator it runs on AC, obviously. If you have battery disconnect switch on and inside dial on fridge on and plug in shore/generator it is not clear to me if the refridge automatically starts running on AC or is still running off DC battery which is now being charged by AC since the battery disconnect switch is on. But for sure, once you turn the dial inside fridge to zero the fridge turns off. The inside light does not come on when you open door. Just my experience starting my lwn “shakedown” and “getting to know” processes.
smsasf is offline   Reply With Quote
Old 07-06-2020, 05:08 PM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you have 30 amp service (I do), I would suggest a 15 amp male to 30 amp female and a 50 amp male to a 30 amp female. This allows you to plug into power at 15 amp (generator), 30 amp and 50 amp outlets. I also carry a 25 foot 30 amp extension as well as extra water hoses and a water y adapter.
RV sites are like a box of chocolates, you never know what you are going to get!
Richard
Old 07-06-2020, 05:23 PM   #19
2015 28' Flying Cloud
Newtown , Pennsylvania
Originally Posted by GCinSC2 View Post
Eirka,
Gary
Using a neutral grounding plug will surely trip the GFI on the generator.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 07-06-2020, 05:54 PM   #20
GCinSC2's Avatar
Bruce,
I have same Honda 3000 and used a bonding plug. No problem.
Mike Sokol is one smart RV power guru.
Gary
S/OS #001
Help with C channel crushed -- dry rotted plywood Tony S Repairing/Replacing Floor &/or Frame 12 04-26-2013 09:10 AM
'91 Excella 29' need to repair or sell parts - Tree crushed rear bedroom Charles H. 1990 - 1993 Excella 7 03-16-2008 08:14 PM
crushed front end art tramp Ribs, Skins & Rivets 1 07-23-2006 01:10 PM
Crushed Umbilical heyskipper Lights - Interior & Exterior 3 02-23-2003 08:23 PM
