Tend to agree on getting a good cell receiver rather than a booster. Not had much luck with the latter, but we bought this and it's been great - able to work remotely with video calls/VPNs etc with no issue in most areas...
https://www.mobilemusthave.com/Ultim...rk_p_1213.html
Mobile must have has a bunch of other bundles too...
https://www.mobilemusthave.com/Mobil...dles_c_44.html
The main issue is that anything like this needs its own sim, and those plans can be expensive, but there are a variety out there - these guys always have good recommendations...
https://www.rvmobileinternet.com/
In terms of the antenna, we installed the 7-in-1 (ie 4 cell antennas, 2 wifi and one GPS) mobile mark on top of our rear AC unit. We then leave one wifi antenna on one of the inside "bunny ears" and use one of the two on the roof. The roof one has the metal roof in between it and inside (unlike on a non Airstream RV) so isnt much use inside, but is great outside. The combination of one of each works great!
We also bought one of these, which we use on a pole in place of the roof antenna when there's not quite enough signal, but we rarely have to
https://www.mobilemusthave.com/XPOL-...na_p_1280.html
Here's a roof view and a view from the side where you can see it sticking up just higher than everything else
