Old 11-23-2022, 07:57 AM   #101
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Hi
I spent 40+ years designing this sort of stuff. That's what you are going to run into.
If you want the heaters on all the time, just wire the switch lead to the battery post. The thermostat will handle the rest.
You’re quote;
“If you want the heaters on all the time, just wire the switch lead to the battery post.
The thermostat will handle the rest.”
Me;
If it wired as suggested in your post. The heaters will only be active for the time needed to heat the battery(s) to the temperature that they can receive a charge.
What are you referring to as a ‘thermostat’ in your example?
Silvr_Bullet is offline   Reply With Quote
Old 11-24-2022, 07:34 AM   #102
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Originally Posted by Silvr_Bullet View Post
You’re quote;
Me;
Hi
As mentioned earlier, when you hook up the signal to turn on the heaters, a thermostat cuts in when they get below about 40 degrees. They heat up to about 50 degrees and it cuts out again. They cycle between the two points as long as the "heaters are turned on".
Winter Boondocking on Lithium CMHM Full-Timing, Winter Living & Workamping 56 04-24-2022 06:18 PM
The Future of Boondocking: In-chassis 14.3-kWh lithium battery jeffmc306 Off Topic Forum 7 12-22-2019 12:00 AM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 10:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 07:44 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
