Hi
Under no circumstances let your dogs sit down and have a heart to heart conversation with our Neuf. He has come up with an "innovation" on the bedding issue. It involves him pouncing on it, regardless of it's location. This *might* be related to his deciding that breakfast is due at 6 AM and that daddy isn't moving ... yet...
Bottom sheet on ours stays in place based on "bed suspenders" holding it there. If you *really* want a grumpy wife, ask her if the sheets need to be suspender sheets need to be changed
Since the stupid clip things are already there, fastening the bottom end of the top sheet to them works pretty well. Tying in the first blanket to the same also works.
How well tying in the wall side of things with the same clips works is TBD. I'm not a big fan. The process also does not work very well on the high loft top blanket that keeps the propane use manageable. It occasionally joins the Lab on the floor. He likes it a lot. The Neuf doesn't have a chance if it heads for the floor.
Our trailer came with power gizmos to raise your head. They are in storage. The stock mattresses (from 2017) are no longer with us. Thicker "upgrade" mattresses are in their place. This was at the request of she who must be obeyed.
Sheets are all very normal "bought on Amazon" versions. The custom AS stuff is somewhere The Amazon version works no better / no worse than the AS stuff. The Amazon top sheet is a bit wider than the AS equivalent.
