Go Back   Airstream Forums > Airstream Community Forums > Boondocking
Old 04-14-2019, 07:08 PM   #1
2019 16' Sport
Winter Park , Colorado
Are USB's in Sport hot with DC power when boon docking?
Hello All,
I just put a deposit down on a 2019 Sport 16'. It will come equipped with solar, however, my model does not have an inverter installed. Are the USB ports able to charge phones/ipads etc when not hooked up to city power or a generator?
Nickutrumbos is offline   Reply With Quote
Old 04-14-2019, 07:34 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
While I don't have any experience with the model you mention, I would be very surpised if you do not have power at the usb points.
what you wont likely have is 120v outlets without shore power.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 04-14-2019, 07:47 PM   #3
2007 22' International CCD
Most Airstream trailers that have USB charge outlets have them powered off the 12 volt system. As long as you have battery use/store switch set to ‘use’ and your battery has power the outlets should work.
Old 04-14-2019, 07:51 PM   #4
2019 22' Sport
Carlsbad , California
My Sport 22’ has power to the USB ports when the battery switch is on. Should be the same for you.
Prettygood is offline   Reply With Quote
Old 04-15-2019, 09:50 AM   #5
2019 22' Sport
sammamish , wa
just picked up our '19 Sport 22. the USB is hot on battery and manages the phones just fine. that said, there may be a limit how much power is on the circuit. I tried to run my CPAP using a 12V adapter(12 V cigarette adapter to CPAP paired with a Female cigarette to USB to connect to AS). It powered on the device fine but power cut off when the CPAP was on. I was able to get the CPAP working using my portable 250W inverter, so I know a 12V DC solution can work. just not sure if the limit here was the AS USB or the USB to cigarette adapter I used.
TikiRoom is offline   Reply With Quote
Old 04-15-2019, 10:07 AM   #6
ProTech's Avatar
2017 23' International
Portland , Oregon
Yes.
ProTech is offline   Reply With Quote
Old 04-15-2019, 11:06 AM   #7
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
A USB port is only good for an amp or two on a good day. Stepping the 5v USB up to 12v cuts that available current by 60% or more. In contrast a CPAP would likely need on the order of 3-5 amps at 12v.
daleyocum is offline   Reply With Quote
Old 04-15-2019, 11:12 AM   #8
2017 16' Sport
Anywhere , IN
Greetings,
I have a 2017 16ft Sport.
My usb’s have power while not using shore power.
In reference to a cpap, I don’t believe a standard usb has ability to run a cpap. In my sport, I added a 12 volt cigarette adapter, near fuse box, and purchased 12 volt cord for cpap, Amazon, that is made for my particular Cpap. I also replaced my stock battery with 2 six volt Trojan t125’s.
Safe Travels.
KRPS is offline   Reply With Quote
Old 04-15-2019, 11:29 AM   #9
Wolf Alaska's Avatar
Madison , Alabama
Images: 8
The right way & the wrong way
The typical robust USB provides 2.1 amps @ 5VDC
That is 10 watts. It is not much.
There is no way to step up direct current from 5V to 12V. Cars use ignition coils OK, but only for momentary impulses to fire sparkplugs.
Your CPAP likely runs on 12V direct current. See if you can get a source for 12VDC & cord for your CPAP. I made mine. When you use an inverter, it wastes about 20% of the electricity.
BTW a 250 watt inverter probably is a MSW inverter. That power may shorten the life of your CPAP. Was yours cheap? Mine wasn't. I would only use PSW inverter for a CPAP. Battery 12VDC should be OK.
Wolf Alaska is offline   Reply With Quote
Old 04-15-2019, 12:38 PM   #10
Silver Sanctuary
2019 25' Flying Cloud
San Diego , California
CPAP Option
I have a FC 25RB, and replaced the bedside stand 12v USB outlet with a combined USB and 12v dual-socket combo - see the link below for the Marinco unit on Amazon (I hope this messages posts an active link - it shows it in the preview, but I'm still a newbie on Airforums ).
The the rig in "use" mode, the 12v socket enables my wife to run her CPAP when there's no shore power without having to run the inverter. Besides the breathing function, many CPAP machines have an integrated "humidifier" capability so the users nose/throat doesn't get so dried out. Vaporizing the water to humidify the CPAP air requires a lot of power. So, to use the 12v socket at lower wattage, hopefully you can disable the humidifier if you've got that feature.
https://www.amazon.com/MARINCO-12VCO...07572497&psc=1
slvrsnctury is offline   Reply With Quote
Old 04-15-2019, 09:03 PM   #11
daleyocum's Avatar
Portland , Oregon
These days there are all matter of solid state boost converters that can step up a lower voltage to a higher one. It’s just that a USB socket, as you mention, can’t provide enough current to run a CPAP.
Old 04-16-2019, 06:04 AM   #12
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
Just install one of theses...easy to do. If in the bedroom, you will want one without a light.
Below Deck Charging Panel - 2.1A Dual USB Charger & 12V Socket https://www.amazon.com/dp/B01AYOSD50..._KrCTCbVEA8RD5
billrector is offline   Reply With Quote
Old 04-16-2019, 07:18 AM   #13
2018 16' Sport
Como , Colorado
I have a 16 ft 2018 Sport. what kind of inverter do you have. I'd like to run my CPAP when boondocking
judithk is offline   Reply With Quote
Old 04-16-2019, 08:23 AM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My old CPAP ran on 12 volts. I ran it on the 12 volt system just fine. My new CPAP is 24 volts. I purchased a 12 volt to 24 volt supply and run the CPAP on the 12 volt system now also. I ran it on a small 110 inverter for a while before I got the 12 to 24 volt supply. I think there is no way a USB could power a CPAP. I looked at the small lithium battery options specifically for CPAP. An awful lot of expense for almost no power. The two big trailer batteries look like a much sounder option for me
Old 04-17-2019, 07:42 AM   #15
2018 16' Sport
Como , Colorado
I have a top end travel CPAP so likely would would work, esp without humidifier.thanks
Old 04-21-2019, 11:58 AM   #16
Clearlake , California
I believe the limitation is the amount of current a USB can deliver. My CPAP draws 3.75 Amps at 24 Volts (90 Watts). At 12 Volts that would be 7.5 Amps. Most USB ports only supply a maximum of 2.5 Amps. I would look at tapping into the 12V wiring before the USB port and use a different plug for the CPAP, such as XT60 types.
napabill is offline   Reply With Quote
Safe to leave trailer when boon docking? Omnial Boondocking 38 08-24-2021 09:52 PM
Fridge boon docking duration time question. jmpgino LP Gas, Piping, Tanks & Regulators 10 04-16-2017 08:23 PM
Another boon docking option, coming soon. Photobum Airstream Lifestyle 10 05-26-2015 03:20 PM
Estimate of battery life when boon docking RVDreamer Electrical - Systems, Generators, Batteries & Solar 23 03-28-2015 08:29 AM
Boon Docking In PEI and Nova Scotia breezyway Boondocking 2 03-06-2014 05:26 AM
