You said 12.5 this AM with generator running all night, then you said 13.3 with gen running. Confusing...which is it? If your generator was running all night did you let the batteries rest at no load before measuring voltage? That is the only way to check battery state of charge. With the charging source running you should see 13.3-13.6 on the battery but that only tells you that it is charging, no how much charge it held. If your batteries were 12.5 at rest(after 30 minutes of no load/no charge) then they are pretty close to fully charged, for which I have always used 12.6. Same thing after a day of driving...was the 12.5 at rest?
larry
