Old 08-09-2021, 11:12 AM   #1
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
12 Volt Fans
12 v fans are important if you are boondocking. Excuse me if this has been covered already in another thread, but I used the search engine to find “12 Volt Fan” threads and came up empty.
The standard for the best 12v fan has been the “Endless Breeze” fan by FanTastic. We have had one for 6 or 7 years and it has worked great. We paid about $60 for it. I stumbled across a Chinese knock off of it called the “Boundless Breeze” fan available from Amazon for $40. I checked the price of the Endless Breeze fan and it is now about $110. I ordered one and the performance is very similar to the Endless Breeze. Now I didn’t do a detailed comparison test with noise levels and current measurements. I may do this later.
I became aware of some other 12v personal fans at the vintage Airstream rally in Tennessee a few weeks ago and ordered some.
The first one I ordered was a personal desk fan with a rechargeable battery. This will run 200 hours! The battery gives it some weight so it is very stable. It works well sitting on a table outside with you sitting next to it or on the counter keeping you cool in the kitchen. You can also aim it straight away, up or down. This is a nice feature. We tried it at night sleeping, but the lights are too bright. We really like this fan and it is $40 from Amazon. We will probably order another one so we each have one while sitting outside under the awning.Click image for larger version
ID:	401384Click image for larger version
Now we have usb receptacles available next to where we sleep so I ordered two 6” fans that operate while plugged into usb receptacles. They were only $15 from Amazon. These work great while sleeping. These can also be aimed. We run them on low and they are very quiet and no bothersome lights.
DanClick image for larger version
ID:	401387Click image for larger version
Old 08-09-2021, 01:17 PM   #2
Mollysdad's Avatar
I have a very small fan that's powered by USB. I run it at night in the bedroom. It's a lifesaver when it's really still.
Mollysdad is online now   Reply With Quote
Old 08-09-2021, 01:23 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
One thing to watch out for:
Not all USB outlet gizmos are created equal. Some are crazy inefficient and produce a lot of heat as a result. They may not be the best thing for running something overnight. Indeed a 12V fan and 12V outlets would always be better. If only the world would standardize on a small 12V outlet .....
uncle_bob is online now   Reply With Quote
12 volt
24 volt or 12 volt solar panels advantages?? purman Electrical - Systems, Generators, Batteries & Solar 13 09-06-2012 02:29 PM
fans or no fans goransons Refrigerators 8 12-31-2007 12:21 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
