Old 09-21-2020, 12:01 PM   #1
Perpetually Perplexed
Krek's Avatar
Mobile Rail Bunkhouse
Farmington , MO
Where to Source Old Style C Channel
SkyhighRV no longer sells the older style C channel.
Internet searching has me coming up empty... is there a source?
Krek is offline   Reply With Quote
Old 09-21-2020, 12:39 PM   #2
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
If it's just C channel like on my 60 and 61 any fab shop can whip it up from .040". I ordered extra as it's handy for stiffeners in the walls and all sorts of things that crop up. I like it with one leg longer than the other as it makes riveting simpler for a novice helper.
truckasaurus is offline   Reply With Quote
Old 09-21-2020, 12:54 PM   #3
Krek's Avatar
Farmington , MO
That’s great info, I’ll bet the aircraft supply close to me could fab that.
Any advantage to using slightly thicker material or is the .040 good enough?
Old 09-21-2020, 01:59 PM   #4
1960 33' Custom
Athens , Georgia
Thicker holds itself better when the belly pan tried to deform it but I think .040" is still a good option, .032" may be a bit weak unless your belly pan is already formed well. You may want to double check your existing channel and decide if you want both angles to be 90 or if something like 94 may work better. I went with 90 and just adjusted as I went. Prior to installing a shot of suitable primer can't hurt either.
Old 09-21-2020, 02:01 PM   #5
1966 22' Safari
Fredericksburg , Texas
I ended up buying some 1 1/2” x 1 1/2” x 8’ square tubing. I took a jigsaw, broke about 3/8” off a metal blade so it wouldn’t bottom out and split one side at a time. I believe it may have been 18ga from one of the box stores. Just another option.
Bubba L is online now   Reply With Quote
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 05:20 PM
U channel or C Channel???? vintageracer Repairing/Replacing Floor &/or Frame 5 01-24-2016 06:49 AM
Old Style Sofa Vs New Style settee Opinions Needed Jim Clark General Interior Topics 3 01-23-2013 02:53 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
old style brake conversion to new style Justmeandshe Brakes & Brake Controllers 1 06-23-2007 05:16 PM
