Old 07-22-2020, 02:18 PM   #1
1973 31' Sovereign
lynn Haven , Florida
What is this called and how do I remove it?
Can someone tell me what this is called? Different name than a rib?
I'm having a hard time removing it from the airstream. Is there something I'm doing wrong other than trying to wiggle it off?
musicman74 is offline   Reply With Quote
Old 07-22-2020, 08:45 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It's called a stringer, and why do you need to remove it.
Old 07-23-2020, 08:49 AM   #3
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
You won't be removing that unless you remove all the spray foam surrounding it. A stringer is usually fastened to the wall (skin) similarly to a French cleat, except on both the top *and* bottom. Sometimes a stringer is just riveted to the outer skin. Either way, it will take some serious effort to remove it, especially with all that spray foam.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 07-23-2020, 12:24 PM   #4
Sag Harbor , New York
Is this the same trailer as in your earlier thread?
https://www.airforums.com/forums/f46...es-207347.html
Originally Posted by musicman74 View Post
I bought my airstream completely bare.
Echoing the comments that it will be much harder to remove now.
Good luck,
Missing knob - where can I get one and what is it called? Doc Foster 2011 - 2015 International 2 05-30-2016 03:43 PM
What is this Black Water Connection called, and where can I find a cap? StevieB Waste Systems, Tanks & Totes 20 02-21-2015 07:23 AM
What is the velour wall covering called in my excella and should we put it back up? mikeandnora Upholstery, Blinds, Walls & Interior Finishes 3 06-12-2012 09:04 PM
What is the "rain channel" over windows and doors actually called? Rob&Julie Windows & Screens 3 01-19-2012 08:26 PM
What is this thing called and where do I buy a new one? jimmieanna Waste Systems, Tanks & Totes 13 06-20-2011 09:46 PM
