11-02-2017, 11:31 PM
1970 25' Caravanner
Incline Village
, Nevada
The sky fell on my airstream, dent repairable?
Woke up one morning and saw this on my poor AS. I suspect a large chunk of icy snow fell from the pine tree I was under. Question is, can this be a DIY repair or leave it to the professionals? If DIY (and I do like a challenge), any suggestions would be appreciated.
11-02-2017, 11:42 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I think most of that would pop out if you removed the end cap and pushed them out.
11-03-2017, 02:10 PM
1986 25' Sovereign
2008 F350, 6.4L diesel
, Oak Harbor, WA
There is a thread where a user made a large doughnut put it on the dent and pulled a vacuum on it. Popped out the dent without any work on the inside of the trailer.
11-03-2017, 02:15 PM
Central
, Mississippi
http://www.airforums.com/forums/f4/h...ap-153091.html
I helped a friend remove a bird strike dent using this method. Amazing.
11-03-2017, 02:17 PM
2007 22' International CCD
Corona
That was the tire inner tube that fit around the dent, a piece of plywood with a hole in the middle that accepts the hose from a shop vacuum trick.
Vacuum does all the work, in concert with atmospheric pressure from the other side. Be sure to use a 'fat' enough inner tube that the skin does not hit the plywood when the dent pops.
With a bit of luck, it might pull out with minimal traces.
Other possibility is a "Paintless Dent Repair" service that uses either suction cups or glue-on tabs to pull the dent. This one does not appear to have creases, so the above methods may work well.
11-03-2017, 02:31 PM
1995 30' Excella
Harper Woods
, Michigan
Maybe a trip to a body shop would be a good idea. People there pop dents often.
11-03-2017, 04:16 PM
Overland Adventurer
2009 34' Panamerica
Telluride
I vote a suction cup from a GPS will pop the majority of this dent out!
11-03-2017, 05:13 PM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
I have one of these and it would pull that dent easily
https://www.autobodytoolmart.com/bod...r-p-13504.aspx
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
11-03-2017, 07:15 PM
1974 Argosy 26
Morrill
, Nebraska
Look for my thread using an Inner tube, plywood and shop vac.
It worked for me.
11-03-2017, 09:40 PM
1970 25' Caravanner
Incline Village
, Nevada
Inner tube
Love the idea of inner tube with suction. Sure beats $4000 when perfection is not desired. If it doesn't work then there is always the professional. Will post update and photos when I get around to this. And thanks to all for the suggestions.
11-04-2017, 02:58 AM
2011 27 FB International
East Coast
, Newfoundland
I also used the inner tube, plywood and shop vac method on an end cap dent. Worked surprisingly well on a surface curved in two directions.
[AIR# 55762 TAC# NFL-1
