Old 06-03-2019, 06:35 PM   #1
2019 22' Sport
Glen Allen , Virginia
Sport casualty
So...this is what happens when a lacrosse ball hits a very expensive tin can. Any ideas on how to pull out the dent?
DJBiggieSlim is offline   Reply With Quote
Old 06-03-2019, 08:16 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
It should be pushed out from the inside and I know that is a pain. That does give you the opportunity to reseal the joint and replace any damaged/loose rivets with buck rivets vs. Olympic.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 06-03-2019, 08:22 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I tried a slide hammer suction puller on a similar dent and it would not budge it. That seam is pretty rigid. Puller worked great in areas with no seam.
Old 06-03-2019, 08:24 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
It isn’t going to “pop” out, but some of the forums participants had had pretty good results getting dents like that out using “pointless dent removal” techniques. There is a thread where the poster used a piece of plywood and a spall inner tube to “suck” a dent out on the end cap using vacuum. Search for “inner tube dent removal” and you can probably find that thread.
Good luck!
Old 06-04-2019, 07:52 AM   #5
dznf0g's Avatar
Oswego , Illinois
I am afraid, because it is on a seam, that attempts to suck, or pull, or roll out will be ineffective and/or unacceptable. IMO, this is an insurance claim and JC repair @ Roughly $3500.
-Rich-
Old 06-04-2019, 11:38 AM   #6
2007 22' International CCD
Sport casualty
It’s worth a try. A sheet of plywood and a small inner tube from a wheelbarrow or the like just big enough to span the dent might do the trick.
Old 06-04-2019, 11:56 AM   #7
dznf0g's Avatar
Oswego , Illinois
Not until the adjuster takes a look and writes an estimate. Otherwise, the insurance company may deny it when it turns out badly.
-Rich-
Old 06-04-2019, 12:51 PM   #8
Sport casualty
True. Very true. Any excuse the insurance company can use to deny a claim they will use.
Get an independent appraisal always! The insurance company’s adjuster is guaranteed to be biased toward the outfit that gives the paycheck...
Basecamp, Sport 16, Sport 22, FC 19? Twitterpated 2005 and newer - Bambi all models 49 04-26-2017 04:53 PM
Sport 16' :: 2015 Airstream Sport DanielRDR Airstream Registry Discussions 0 10-05-2016 10:58 AM
2013/2014 Bambi Sport 16' Sport Wrap Windows in back? maureencrist 2005 and newer - Bambi all models 7 04-21-2014 08:46 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
Airstream Sport 22 :: 2011 Airstream Sport Lone Eagle0 Airstream Registry Discussions 0 08-19-2011 08:32 AM
