Old 04-24-2020, 09:08 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Solid rivet length
Hello from voluntary social isolation.
So I've purchased the assorted solid rivet sizes from Vintage Trailer Supply including the 3 lengths of the 1/8" shank and the 3 lengths of the modified 5/32" shanks. I''m about ready to reattach my shell to the frame, (92 Excella) or more precisely to the aluminum floor channel that surrounds the perimeter of the floor. I understand the 1-1/2 - 2 protruding shank length to shank diameter ratio. That said was wondering if anyone can tell me the most common shank length (1/4", 3/8", 1/2") for attaching shell skin to the floor channel (I'm guessing 3/8"). I worry about having enough so am thinking about ordering some additional before I start, but would like to get the correct length.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 04-24-2020, 09:13 PM   #2
Boxite's Avatar
2008 22' Safari
You want the “bucked end” of the rivet to “swell” to be approximately the same size as the rivet “head” ...or to be twice the diameter of the rivet shank...after it is bucked. I.E., you want the rivet to be about 3/16” longer than the depth of the hole.
Solid rivet question 65 wonton Ribs, Skins & Rivets 2 11-15-2011 04:13 PM
Solid Rivet Styles - Data Zeppelinium Ribs, Skins & Rivets 27 04-09-2010 08:51 PM
solid rivet size Frank's Trailer Works Ribs, Skins & Rivets 27 09-14-2009 05:45 AM
Solid rivet length Annabel Ribs, Skins & Rivets 3 05-18-2006 08:08 AM
