Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-20-2017, 10:00 AM   #1
anderson , South Carolina
skins that are the same
I passed on many mid year models due to need to replace corners. I know these panels are not available and practically impossible to make (early 60's models). I;m thinking about donor models.. are the corners on the larger models the same as the small ones? big airstreams can be cheap sometimes, can a corner from one of these be installed on a bambi, bubble, other small ones.
ohpoppy is offline   Reply With Quote
Old 12-20-2017, 11:38 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
All the 50's and 60's trailers except the 69 have flat sheet lower corners made from alclad .032 2024-T3.
If you are talking the upper corner segments, then it's a different story..
Old 12-20-2017, 04:03 PM   #3
I am talking the upper corners.. are larger or largest airstream corners the same?
yes I know rivet holes are never that exact but the shape of the skins, are they the same
Old 12-21-2017, 10:04 AM   #4
Aerowood's Avatar
Arvada , Colorado
The upper corner segments are different on different years and I don't know the exact splits, Late 50's to 68 are the same (I think) 69 to 80 something, then the late models wide bodies. Hopefully someone else here has the exact dates.
Some people have had good luck removing them and reforming on an English Wheel. There are several methods for removing dents depending on the severity of the dent.
File Type: pdf History of Aluminum at Airstream (1).pdf (58.2 KB, 17 views)
Same old, same old whitegs Tow Vehicles 36 08-11-2016 04:22 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 08:23 PM
Inner skins - just how structural? malconium General Interior Topics 4 06-30-2004 10:23 AM
door skins...need advice surf'n safari Ribs, Skins & Rivets 5 12-16-2003 11:15 PM
Replacing Skins NSMITH Ribs, Skins & Rivets 8 06-04-2002 04:02 PM
