Old 10-14-2018, 08:45 PM   #41
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Looks good,
To remove a deviation from the correct curve you only need to have the wheel positioned so that the errant material will contact the wheel. If the skin has the correct curve the wheel will barely touch the material if at all.
I found that I prefer to move the material that was pushed in first then switch or flip the part over to work on the outside. Using a marker to show where a ridge was also help to keep the wheel straight.
A lot of this work needs a helper that can hold the other end of the skin and allow the skin to flow over the anvil. If you do not work in concert the material will become jammed and that is not good.
sgschwend is offline   Reply With Quote
Anyone know English wheel metal fab in Bay Area CA twolanehwy Ribs, Skins & Rivets 8 05-17-2016 08:44 AM
English Wheel douglasbury Ribs, Skins & Rivets 10 11-25-2015 09:04 PM
Can these dents be worked out on an English Wheel? gronlampa Ribs, Skins & Rivets 12 09-07-2015 01:50 PM
$12 English Wheel, for the Bananas Globestream Belly Pans & Banana Wraps 10 06-04-2012 05:43 PM
English Wheel Users? ALANSD Ribs, Skins & Rivets 12 03-04-2004 09:26 PM
