Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 07-13-2020, 03:48 PM   #1
2004 25' Classic
Hanahan , South Carolina
Scratches or some kind of road film?
I am upgrading to taller segment protectors and trying to clean this area that is above the shorter ones.
It doesn’t seem to clean so I’m beginning to think they are small scratches and maybe some corrosion starting. What do you think? Have you seen this before?
Planenut is offline   Reply With Quote
Old 07-13-2020, 03:52 PM   #2
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
That's fillaform (corrosion). If you look closely at many of them you will most likely see where tiny rocks/debris has hit the coating making a pin-hole that gets it started.
RivetED is offline   Reply With Quote
Old 07-13-2020, 07:00 PM   #3
2004 25' Classic
That’s what I had guessed..
There is not much to do about it I imagine until you are far enough along to polish the entire trailer?
Old 07-13-2020, 08:11 PM   #4
RivetED's Avatar
Airstream - Other
Airstream - Other
CorrosionX or Boeshield T-9 are the best products I know of that is supposed to stop/minimize filiform.
I haven't looked into filiform for a while, try searching these forums and there will be a lot of threads about it.
Proud new owner of some kind of aluminum trailer! IanRae Member Introductions 11 01-29-2015 10:48 AM
Some kind of short out... help? Friday Water Heaters, Filters & Pumps 13 09-14-2011 11:49 AM
some kind of wrap for the bottom annegregory Belly Pans & Banana Wraps 3 10-21-2010 07:16 AM
some interior work that was kind-of fun funkill Upholstery, Blinds, Walls & Interior Finishes 5 01-06-2009 08:06 PM
Need some advise maybe a Rally of a different kind.. JodynJeep Our Community 5 02-01-2003 11:11 AM
