Old 05-08-2019, 08:34 PM   #1
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Rusty Awning Rivets
I have a 2013 Flying Cloud that came from the factory with only the main awning. In 2014 I had an independent shop install the rear and street side awnings.
I was just cleaning the roof and I noticed that about half of my street side awning rivets are rusty. There seem to be three kinds of rivets: Aluminum olympic rivets (about every five rivets) and a mixture of aluminum and steel
(now rusty steel) standard pop rivets. There is no sealant on the rivets.
My curb side awning has sealant on each fastener.
How bad is it that some of these are rusting? Should they be covered with sealant? If so, should the rusty rivets be replaced first?
SSquared is offline   Reply With Quote
Old 05-08-2019, 08:52 PM   #2
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Good question. I have a 2015 23d and added rear and street side awnings in 2018...following.
FloydCoVa is offline   Reply With Quote
Old 05-08-2019, 09:00 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
That “Independent Shop” did not install your awnings with the correct hardware. When I purchased my awnings from ZipDee they came with all the hardware needed to install.
Steel pop rivets should not have been used. They should be removed and replaced with Olympic rivets.
Here is the blog post of my install.
http://www.airforums.com/forums/blog...national-2925/
http://www.airforums.com/forums/blog...l-part-2-2926/
http://www.airforums.com/forums/blog...l-part-3-2927/
Old 05-09-2019, 06:21 PM   #4
SSquared's Avatar
Longmont , Colorado
GMFL,
Thanks for your reference to the other thread. It looks like my street side awning has more rivets than yours--maybe the installer used what was provided and then added more in the interest of overkill. (My factory-installed curb side awning has many fewer fasteners; I don't know what type they are because they are covered in big globs of sealant)
Did you add sealant over your rivets? Is there a risk of water leaking through the center hole of olympic or normal pop rivets?
Rivets, Rivets, Rivets PSU1981 General Repair Forum 3 07-17-2018 12:02 PM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Rusty Rear Awning Retention Struts – SOLUTION withidl Awnings 7 01-03-2014 04:40 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
