Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-24-2020, 03:59 PM   #1
1987 31' Excella
Hailey , ID
Question Roof panel damage repair
A PO removed the entire rear exterior endcap and ended up causing damage to the roof panels that run all the way down the trailer. I obviously want to avoid replacing the entire roof panels.
Any ideas out there on how to fix these bent up panels? I thought about cutting these sections out down to the nearest rib, which is about a 1 foot section, and putting in a new piece of aluminum. That way at least I can get these edges nice and flat and clean looking, and sealed well. Does anyone see any possible problems with that?
I do have the interior skins off, so I know I can just seal it really good from the inside, but I also want the exterior to look good.
any thoughts are much appreciated!
And if you're interested, I'd love to have you follow along on my first Airstream Renovation: https://youtu.be/FhuPb2W_9Zw
ID:	368637   Click image for larger version
ID:	368639   Click image for larger version
wildwonder is offline   Reply With Quote
Panel on Panel Repair moosetags Ribs, Skins & Rivets 13 03-14-2019 04:42 PM
Exterior panel damage - need repair shop recommendation plkallina Ribs, Skins & Rivets 0 01-22-2018 07:31 AM
1974 Sovereign Roof Panel Repair Auto Bliss Clearcoat, Exterior Paint & Trim 2 07-01-2016 02:36 PM
AC Roof damage and repair with added support HiJoeSilver General Repair Forum 0 07-14-2015 05:56 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
