Old 03-29-2017, 11:30 AM   #1
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Rivet question
My 67 Overlander International is missing a few rivets from the body trim pieces. Some go through trim and skin only and some go through wheel wells as well. What rivet type, material, diameter, and length do I need to use?
BambiTex is offline   Reply With Quote
Old 03-29-2017, 12:43 PM   #2
Boxite's Avatar
2008 22' Sport
Most trim is attached with common "pop" rivets. You'll need to look at each situation and decide the depth and diameter of the rivet to use. If you've never used pop-rivets, you might get the home depot guy to show you. They're pretty simple actually.
Old 03-29-2017, 12:46 PM   #3
dznf0g's Avatar
Oswego , Illinois
Also, once you determine length and diameter, Chek and see if blind pop rivets are available. They are water tight through the center barrel. Still seal the perimeter.
-Rich-
Old 03-29-2017, 01:03 PM   #4
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
I have a rivet gun and know how to install pop rivets. Just wanted to know recommended rivet length and diameter.
Old 03-29-2017, 01:05 PM   #5
dznf0g's Avatar
Oswego , Illinois
I wouldn't be comfortable enough with build consistency to claim any 2 units would be the same. I'd try and measures what you have.
-Rich-
Old 03-29-2017, 05:38 PM   #6
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Get 1/4 and 1/2. I'm sure you'll use both.
Cyquest is offline   Reply With Quote
Old 03-29-2017, 05:39 PM   #7
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Just make sure they are aluminum with aluminum mandrel.
Old 03-29-2017, 07:11 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have good luck with the 5/32" diameter pop rivets. I keep three "grip ranges" in my tool box, I'll say short, medium and long. I also keep the larger 3/16" diameter pop rivets in stock too. I use these for bigger jobs like belly pan attachment.
I very seldom use the Olympic tri-fold rivets as they are very weak even though they can be shaved to look like a bucked rivet. Olympic rivets are for light duty jobs like holding the Airstream insignia on in my view. I used them for that job as they look pretty.
Bucked rivets are the strongest and seal the tightest. But alas, I haven't purchased a pneumatic riveter or bucking bar yet. Seldom to I have access to both sides of the piece I am repairing.
David
dbj216 is online now   Reply With Quote
Old 03-29-2017, 08:00 PM   #9
Boxite's Avatar
2008 22' Sport
Anytime you want to seal a pop-rivet, just dip it into your preferred sealant before you "pop" it and let it cure. I've used Permatex #1 gasket sealant quite successfully, as well as RTV/Silicone in the appropriate locations.
Wipe off the excess and let it cure.
Old 05-15-2017, 10:08 AM   #10
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
David
So you're saying don't bother with the Olympic rivets even if it's an exterior skin repair?
tonydead is offline   Reply With Quote
Old 05-15-2017, 11:25 AM   #11
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Olympic rivets are OK for exterior patches etc... You don't want to use them for structural repairs though . If it's structural then use bucked rivets.
Dingo Girl is offline   Reply With Quote
Old 05-15-2017, 07:06 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
An Olympic tri-fold rivet is less than half as strong as a pop rivet, and pop rivets are less than half as strong as a solid bucked rivet. The long tri fold legs tend to hit other features behind the surface and get even weaker. Here is a photo of the business end of an Olympic rivet.
If you look at a rivet website, you will see where tri-fold rivets are used for assembling light duty materials, even wood and cardboard. The big spread of the tri fold legs keeps the rivet from pulling through.
One of our vintage Airstreams has some exterior skin repairs using Olympic rivets. We have seen a few of them break and fall out. But this can happen with a bucked rivet too, but less likely due to their strength.
I used Olympic rivets to "patch" a piece for the new furnace in my Trade Wind. I was not satisfied with the results.
I wish one of these rivet makers would design a strong blind aluminum "pop" rivet that the shank, or mandrel, would break above the rivet head so we then could shave it smooth like we do with the Olympic rivet. The Aircraft "Q" rivets are close. And very expensive.
David
Name:	1411 Olympic Rivet (Small).jpg
To rivet or not to rivet? That is the question LavenderMoon Forum Admin, News and Member Account Info 3 03-24-2013 10:07 AM
Rivet on rivet repair Darkspeed Ribs, Skins & Rivets 2 08-19-2011 05:46 PM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 10:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 09:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 05:41 AM
