Old 05-26-2020, 11:11 AM   #1
2018 23' Flying Cloud
Victoria , British Columbia
Rivet popped, Trim coming off on door
When I was cleaning my 2018 AS Flying Cloud FB23 this week in preparation for our first trip of the season, I noticed the trim on the door (midway up the door) was coming off on the hinge side. Upon closer inspection I can see that the rivet that holds the trim on has popped out and there appears to be a crack in the skin of the door (see attached Pic). I am sure we have not pulled of the trim in anyway and unsure if this will be covered by warranty and with our closest dealer, a $300 ferry ride each way to tow the unit wondering about other solutions.
Name:	IMG_1225 (002).jpg
Cdn Camper is offline   Reply With Quote
Old 05-26-2020, 11:55 AM   #2
2014 27' FB International
Lewisville , Texas
Easy Fix
I just went and looked at my 2014 27FB International and that is not a split in the door, that is the seam between the upper and lower half of the door skin that is covered by that trim.
As far as re-attaching the trim, that is an easy fix. The plastic insert in the center of the trim is held on with double sticky tape. Carefully pry off about a foot to give you some working room and cut or drill out the rivet that has come loose.
Then install a new rivet or two to re-secure the trim channel, with your favorite sealant behind it and then re-stick the plastic insert, using glue if needed.
I have found over the years that traveling to a dealer for the small stuff is a huge waist of time, most things you can fix yourself. If you do not have a Pop Rivet gun, you may as well get one with an assortment of rivets, and learn how to use it. Someday, you are going to loose some interior rivets (this is normal) that will need to be replaced. You don't want to travel to a dealer to replace a ten cent rivet that only takes thirty seconds.
Good luck
NO NOIZE is online now   Reply With Quote
My first popped rivet Acheron2010 General Repair Forum 19 08-23-2019 04:52 PM
Finally popped my first rivet. Bobbo 2016 - Current Flying Cloud 7 05-22-2019 12:14 PM
Interior "popped" rivet replacement? MAJORJDB General Interior Topics 11 04-16-2016 07:35 PM
Popped rivet near the top door Hodum Ribs, Skins & Rivets 3 02-21-2012 09:53 PM
Popped a rivet horse sense Ribs, Skins & Rivets 11 04-01-2010 05:58 PM
