Old 08-06-2019, 08:20 AM   #1
2014 25' FB Eddie Bauer
Okemos , Michigan
Rivet Help
I am having trouble figuring out how to replace interior rivets. I get the part about drilling out the old one, but when I look in the hole there seems to be differing situations...in some cases the other surface visible and at about the right depth for the rivet to grab, but in others there appears to be either nothing to grab or it is deeper than the standard rivet grip depth.
What am I missing
Wanna EB is offline   Reply With Quote
Old 08-06-2019, 08:38 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There may be cases where rivets join two sheets of interior skin, and there is no "rib" behind shere they join. In this case, you are just joining .032" sheet to .032" sheet, and it won't appear that there is anything behind there. You can use a very short rivet (1/4") to do this join.
In other cases, you have two sheets that are joining over a rib, in which case you can see the rib inside the hole. It may be flush, or floating around back in there. In these cases, you need a slightly longer rivet to engage it. It makes sense to have a variety of lenths availalbe to you for these different cases.
good luck!
Old 08-06-2019, 08:41 AM   #3
Okemos , Michigan
Super helpful. Thanks much.
Buck Rivet and Rivet BigGrey General Repair Forum 5 05-26-2012 09:29 AM
Rivet on rivet repair Darkspeed Ribs, Skins & Rivets 2 08-19-2011 04:46 PM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 09:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
