Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 09-03-2017, 07:41 PM   #1
1960 22' Flying Cloud
Leavenworth , WA
Question ribs
no not the ones you eat. Has any one made new ribs for an old trailer? I have a 1960 with roof damage (snow load). So I open it up from the inside and found no rebuildable ribs. Thank you
leavenworth is offline   Reply With Quote
Old 09-03-2017, 07:59 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It's has been done. but not by me.
Old 09-03-2017, 08:00 PM   #3
1966 22' Safari
Fredericksburg , Texas
Originally the ribs were placed on a bender that bent an arc. I've had pipe radiused for hand rails before. They used hydraulic or electric rollers. If you can contact a hand rail fabricator, they may have the equipment to bend metal. If they can bend a 1 1/2" square tube, you can split it using a saber saw with a metal blade. The metal blade will have to have about a 1/4" cut off the end so you don't bottom out while cutting one side at a time. That's how we made a lot of the horizontal stringers on our 55 FC. Good luck.
Bubba L is offline   Reply With Quote
Old 09-03-2017, 08:33 PM   #4
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
I did a tradewind last year that had all but 1 1/2 ribs replaced. I had them from a donor trailer. I'm in Yakima. Private message me, I think I know of a few bows around the northwest. I have none left though. Be prepared for a HUGE project. I had about a 1000 hours into the trailer because the aluminum skin all stretches in those circumstances so you virtually have to reskin the entire trailer so you really are building from scratch, or close to.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 09-03-2017, 08:44 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I think what goransons is trying to tell you is this: "you have to know when to hold them; know when to fold them; know when to walk away; know when to run".
If I were you, I would reconsider trying to fix her. It won't be easy, cheap or quick; it will be hard, expensive and slow tedious work.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Smoked ribs Hawkeye5 Stella's Kitchen 10 05-18-2008 11:29 PM
How wide are the ribs in a classic motorhome guy99 Classic Motorhomes 2 02-27-2006 02:24 PM
No Ribs in front & rear??? BornToRock Ribs, Skins & Rivets 0 08-28-2005 10:20 AM
oh my aching ribs desi arnaz Ribs, Skins & Rivets 7 07-10-2005 12:27 PM
Replacement ribs crgintx Ribs, Skins & Rivets 5 01-16-2004 01:27 PM
