Old 03-11-2017, 06:52 PM   #1
Gilbert , Arizona
Replace or cover dented area?
Working on a 46 Spartan that's front panel below the window is scratched beyond repair also has many small dents from gravel hitting it over the years. What to do? I could drill out all the existing rivers and get a new panel cut and riveted in.
For ease of repair could I also rivet a large panel over this area just like a large patch?
What do you guys think?
The original panel was about 10ft long and wraps completely around the front under the bumper rails etc. none of those areas are really effected just right on the front area.
Schneider591 is offline   Reply With Quote
Old 03-12-2017, 12:22 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You could rivet a large repair panel on but in the long run it will be more work then just replacing the whole panel. You could splice in half the panel but with half new and half old you may not like the look. Also check and make sure the panel is not a compound curve. I'm not all that familiar with Spartan sheeting.
Used dented scratched airstream lp tank cover ARGOSYCAMPER All Argosy Trailers 4 10-19-2010 12:59 AM
dented roof panel, with popped seam, Hard Fix?? dkutz Roof 3 02-13-2006 12:27 PM
Dented skin repair from awning rip-off givememoreli Ribs, Skins & Rivets 3 07-18-2005 07:28 PM
help on dented area pinkflamingoes Ribs, Skins & Rivets 40 05-28-2004 07:14 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 08:07 PM
